S Sophias_dad Active Member Supporting Member Jul 29, 2018 3,223 3,877 Massachusetts Dec 30, 2022 #41 Dec 30, 2022 #41 Mamacass said: Thanks. I'll keep an eye on it now that I'm not using AC in the winter. Click to expand... You'll still be using defrost, so count that as AC.
dmurphy Well-Known Member Supporting Member Dec 7, 2018 5,150 7,470 New Jersey - Morris County Dec 30, 2022 #42 Dec 30, 2022 #42 Mamacass said: Thanks. I'll keep an eye on it now that I'm not using AC in the winter. Click to expand... Well, that depends. Remember the AC runs the defroster. And it also doubles as the heat pump (if your car is equipped.) So it may run even in winter … but do keep an eye. Check it - if it’s oily or a non-clear color, get it checked.
M Mamacass Member Dec 1, 2022 8 1 London Dec 30, 2022 #43 Dec 30, 2022 #43 dmurphy said: Well, that depends. Remember the AC runs the defroster. And it also doubles as the heat pump (if your car is equipped.) So it may run even in winter … but do keep an eye. Check it - if it’s oily or a non-clear color, get it checked. Click to expand... Thanks. Car has been sitting in the garage all day with garage doors open. Temp outside is hovering around 60 degrees. No fluid at all on the floor so you guys are right about the defroster and heat pump (I assume it has one anyway). It's a 22LRAWD.
R rrolsbe Member Feb 18, 2017 595 337 Northern Nevada Dec 30, 2022 #44 Dec 30, 2022 #44 Anyone installed the following fender coolant line protection plates from Tsportline on their Model 3/Y? Do any other vendors make a similar product? Looks like it could be fairly cheap insurance from costly damage? Reactions: KenC and AlanSubie4Life
AlanSubie4Life Efficiency Obsessed Member Oct 22, 2018 17,706 23,273 San Diego Dec 31, 2022 #45 Dec 31, 2022 #45 rrolsbe said: Anyone installed the following fender coolant line protection plates from Tsportline on their Model 3/Y? Do any other vendors make a similar product? Looks like it could be fairly cheap insurance from costly damage? Click to expand... Have not installed. Still some exposure for objects in the middle but this will help with this issue. Was wondering when someone would do this.
