Hello,
We went to a popup drive in movie last night. We sat in our model 3 with the headlights manually turned off and the command display set to minimum brightness. The radio was tuned to the appropriate FM station for movie sound. I was careful not to touch the brake pedal. After a time, with no warning, the car turned off - the driver's set went to easy exit, the headlights turn on, the display went bright and the radio turned off- as if we were exiting the car! Caught by surprise I nearly dropped the box of popcorn I had in my lap as i scrambled to turn the exterior lights off again.
Next issue was getting the radio back on. The only way I knew was to tap the brake to turn the car back on, which also turned on the exterior lights. We made it through the movie without any other surprises.
My questions:
Members: What recommendations to you have to make it uninterrupted through a movie?
Tesla - can you add a DRIVE-IN setting?
We plan to attend again next Friday, hopefully we can have a solution by then.
My questions:
