Driver Seat Sensor not recognizing when Driver Gets out
DWGie
New Member
Jul 16, 2017
3
0
Ashburn, VA
My 2017 Model 6 started not turning off the cabin or locking doors when i exited the vehicle. I took to Tesla service and they identified the problem as a bad senor in the drivers seat. They said the only fix is to replace the seat which is $3,500. This seem crazy to me that the senor alone can’t be replaced. Car has 60,000 miles on it so it is out of warranty. Has anyone else had this problem or know of a way (or shop) that can fix this without replacing the whole seat?
Nick B
264
107
Montreal
That price tag seeme excessive. Did you try to ask for Tesla to pay a portion out of good faith? Might be worth asking politely. I was reading another recent post and someone posted a video with a solution... Might be worth checking out
samppa
359
1,592
finland
Here is a 2017 seat bottom. The small yellow connector attaches to occupancy sensor.
Might be difficult but certainly possible to replace.
I'd test by seeing what happens if you just pull that plug..
Jillmark99
202
60
Ontario
It’s sad that in today’s society nobody really wants to “fix” anything anymore. Just throw away and get new.
Tesla telling you they need to replace a $3,500 seat because a sensor is bad is an excellent example of this. I’m sure the sensor wouldn’t be any more then $25 or $30.
Hearing this is very frustrating.
Hopefully you are able to get the sensor fixed somehow without having to replace the seat.
BigNick
Disaffected Member
Dec 3, 2017
1,067
1,299
Pennsylvania, USA
The polar opposite of "sustainability."
whazup
New Member
Oct 12, 2017
2
0
san jose
whazup
New Member
Oct 12, 2017
2
0
san jose
Had the same problem, the workaround is to open and shut the driver side door twice to turn off the middle console. Mine is still under warranty and parts are on order ( entire cushion/ seat). Scheduled a follow up appt to get it install on 1/25.. will update this post then.
domodan
393
176
UT, United States
I have this once in a while. When it happens, I just open the door and press my hand on the seat for a second. Then when I shut the door it realizes I’m gone. Frustrating, but not super frequent. I can also just press lock on the key if I’m out, or if I’m at home as soon as I press the button to open the charging port the car turns off.
EV-Fixme
Vendor
Oct 24, 2019
604
686
Orange County, CA
We had a customer with this issue. That sensor is inside the seat. The customer didn’t want to replace the seat so we hooked up a older sensor removed the the sear bottom (oem seat where switch was visible) and used that as a workaround. Appears to be pretty reliable. Also explained to the customer that it’s not factory and don’t know how long this workaround will last. He seems to be pretty happy.
disclaimer. We are not responsible if anyone decides to do this. Please test at your own risk.
Reactions: SO16 and 2101Guy
tes560
New Member
Feb 12, 2021
UK
I've recently had the same/similar issue; the car going into park at slow speeds and MCU staying on after exiting the car.
Tesla said I needed a new seat base at a cost of circa £2500.
I took the seat out and found the location of the pressure sensor (circled red in pic). It's stuck to the base with adhesive.
I got the part number off the old sensor (1005424-00-A) and called Tesla to find they do in fact sell the sensor separately for £100.
I've now received and installed the new sensor. It comes preinstalled with an adhesive pad to attach to the seat base and there's just one plug to connect.
The car is now working perfectly.
Reactions: 2101Guy
EV-Fixme
Vendor
Oct 24, 2019
604
686
Orange County, CA
View attachment 636085 View attachment 636086 View attachment 636087 View attachment 636088
Thats great! Depends on the seat, some are accessible here, some newer ones are inside the cushion.
Wratran
331
115
Dallas
Isn’t it EVFIXME the same group that was charging people thousands of dollar to replace emmc...when Tesla price was $400....it just suck to see these guys take advantage of the situation
Luckily.. you can get the sensor from Tesla...I would not trust these vendors on this site...they all charge you the TESLA LUXURY TAX
EV-Fixme
Vendor
Oct 24, 2019
604
686
Orange County, CA
Hi Wratran you may be thinking about another group, our eMMC repair ranges from $600-$900 and generally has a completion time of a few days. We introduced our repair to the forum when Tesla was charging $2000 or more having people replace the entire MCU when the eMMC chip has failed. We are also the group that consolidated all the information for forum members to identify many of the symptoms of failure so the owner had enough information about their failed unit and did not have to pay Tesla a $195 diagnostic fee for a failed MCU. We are also letting owners know they can get the repair for free from Tesla, it's even the first line of the post.
Consolidated eMMC Thread (MCU repair) (Black Center Screen)
Alysashley79
1,198
512
Seattle(ish) WA
I had this same issue. The sensor does in fact control the airbag deployment. It started by saying I wasn’t buckled. On and off. Then it didn’t know if I was in the car it not and wasn’t powering down one close door. Played all the games. Then I got the airbag off all the time. My car is still under the btb warranty so they replaced the entire harness suite under the car. It was like $1800 for that. Can you ask for that?
Kaveman
22
FL
A bit off the topic, but(Wratran): I used EVFixMe to get my Tegra board emmc chip changed. Nothing but Great things to say about them and their service. Over the top support to get me going again, and my MCU1 is working great! Cost was reasonable and turn around pretty dang fast. My screen went dark a short time before all the latest recall discussion, making EVFixMe a tried and true route to repair.
Kaveman
Reactions: EV-Fixme
JasonLee
New Member
Mar 12, 2021
Uk
Hi,
What were the 1st signs of failure? I've noticed it takes a while for the speedo area to wake up at the moment.
EV-Fixme
Vendor
Oct 24, 2019
604
686
Orange County, CA
IC wake is likely energy saving if that happens after car is parked a while before using again. A sign of failure is car not shutting off consistently when exiting the car.
