I'm still not sure if we're all talkng about the same think. I jumped to a different definition of "creaking."
GOGR33N: Is the sound a rubbing/creaking sound, like vinyl on vinyl, or a structural metallic creaking?
Hblick48: Did you check which surfaces are rubbing? Vinyl seat against plastic center console? Have you tried treating the vegan "leather" ?
Yes, this is what I'm experiencing as well. Looks like some felt tape may help.I get creaking from the drivers seat. Found out that if I sit with more weight on the right seat bolster, seat touches center console cover and creeks. Goes away if I shift my weight slightly to the left.
You don't need airbags if you have snow to fly into.907XCP: In ALASKA??? Yikes. You're tough!
Definitely not structural metallic creaking. Mine is a 2016, so I have real leather.
Creaking definitely coming from seat rubbing against center console sliding top. I will treat the surfaces to see if it stops, thanks for the suggestion.
My sound is not coming from any rubbing of any materials. I think mine is coming from the supporting bolts. Kinda like a reclining chair when it starts to wear out. I thought if I adjusted the seat up or down it would sound a bit different or go away and it does not. Really only hear it when the G forces from accelerating puts my weight back into the seat or when braking shifts my weight forward.
