Easy iTunes playlist syncing for Tesla USB flash drive
Discussion in 'Model S: User Interface' started by majorlance, Mar 5, 2015.
  1. Captain John
    Captain John Member
    Claremont, CA
    Just a note of thanks for all the hard work it took to make this task simple and painless. Kudos!
  2. sethgodin
    sethgodin Member
    United States
    This is fabulous. Thanks for the generous contribution. Going to try it now...
  3. sethgodin
    sethgodin Member
    United States
    Major Lance, seeing "Unknown Object Type"
    Went through all the steps, several times (thanks for clarifying what CLI means and where the folder is)
    Successfully got the Sudo command to work as seen in your screenshot
    Installed the script
    When I run the script, though, I get the error "Unknown Object Type"
    Thanks for your help...
    seth
  4. rjt65
    rjt65 Member
    Staten Island, NY
    thanks major lance and Ra San, running ra Sans program now. Copying 17,286 files and playlists from my iTunes library. soon hope to hear my songs in my way. thanks again too you both. I love slacker, but sometimes you need to listen to an album or playlist in the order it is meant to be.
  5. rjt65
    rjt65 Member
    Staten Island, NY
    Ra-San: Seems to have worked I won't have time to properly check it until after work tonight. But I seemed to stop copying at S (Not T's to Z). Is there a way to just scan and add missing folders? I just popped in the min i usb this morning so songs appeared but were still loading and I had to exit to go to work.
    I think I may delete and start from scratch as i have a nested old music folder embedded within iTunes Music folder (when they moved xml lib file i had major repairs and this seemed to work so I left a nested subfolder with some duplicates and the missing music). Think I will try to flatten into proper format on my mac pro and than re-run the program and see if it all shows up than.
    Thanks again... I am eagerly awaiting having access to my iTunes playlists and music.
    thanks again
  6. msnow
    msnow Active Member
    SoCal
    Thank you Ra-San!!!
  7. rjt65
    rjt65 Member
    Staten Island, NY
    Ra-San I have an issue:
    i wiped my usb and flattened out my nested music folder. I scan it picks up about 60K files but will not convert any?
    thanks for any help
  8. rjt65
    rjt65 Member
    Staten Island, NY
    Bump ;-)
    :cool:
  9. Mike Maloney
    Mike Maloney Member
    Yreka, CA
    Thanks Ra San! Just discovered your program a few days ago. I was getting tired of doing the Apple lossless to FLAC conversions by hand. Your program is great!
  10. rjt65
    rjt65 Member
    Staten Island, NY
    love the program missed listening to my albums in proper order versus slacker. one issue lot my songs seem duplicated in the tesla but on the usb i see only one song listed.. any thoughts?
  11. BertL
    BertL Active Member
    Carlsbad, CA
    Did you duplicate tracks into multiple folders on your USB stick, e.g. because you put multiple playlists into different folders, and one or more of those playlists duplicate some number of tracks? I suspect so. If you are then playing by the folder tab only, you will only have duplicates if you put duplicates into that specific folder, BUT if you use some of the other tabs in MS Media Player, they only look across all folders and will see the dupes and show them on the non-folder tabs.
    If that does not makes sense, please be a lot more specific as to how you've built and organized your USB stick, and what tabs you are using to playback in your MS. While much of the info is up-thread, THIS page on my personal website may also be of some assistance.
  12. goneskiian
    goneskiian Active Member
    Bellevue WA
    I don't seem to be getting my AIFF files converted and copied. Here is a screenshot from the Teslatunes app...
  13. BertL
    BertL Active Member
    Carlsbad, CA
    This free app isn't (intended to be) a full-blown format converter. From my reading the TeslaTunes ReadMe and GitHub introduction, as well as the example image showing all AIF were skipped, the app appears to be oriented to dealing with FLAC, MP3 and AAC.
    If you need TeslaTunes to provide some of the tagging benefits to circumvent MS (and I assume MX from your sig) Media Player problems, I suggest you:
    1. Use another utility to first convert your AIF tracks (and any other that were skipped) to a format that TeslaTunes will accept (FLAC would be a good choice for your AIFF tracks), placing those converted files into a temporary directory
    2. Then point Tesla Tunes at that temporary set of files as input, so it can take care of the very unique title and tagging changes other utilities are not designed for
    Good luck.
  14. goneskiian
    Bellevue WA
    Thanks. I'd forgotten that AIFF isn't actually Apple Lossless.
  15. goneskiian
    Bellevue WA
    And as it turns out. AIFF is a compatible formet with the Tesla audio system. Fortunately I didn't spend the time converting all my AIFF to FLAC. At least I'll have a little more room on my USB for future purchases! :rolleyes::p;)
  16. tonyj01
    tonyj01 Member
    Manchester, England,
    I wonder why, after another year, this has not been addressed nor solved within the Tesla firmware. Using Spotify does not replace being able to listen and control playlists which many of us have curated over many years.
    I have an iPod with bluetooth but the car will only allow one device to be connected, [therefore phone disconnects] and I feel it is essential to be able to control the playlist from the touchscreen, and to be looking at one's phone or iPod when driving.
    A USB stick will play music, as we all know, though the car, so what small piece of software is missing from the car to allow it to recognise the output from, for example, an iPod.
    Tony
    Manchester
    England
  17. tonyj01
    tonyj01 Member
    Yes I am interested. I will PM you.
    Tony.
  18. Soundchasr
    Soundchasr Member
    Very close
    Windows? Yes!
  19. Infinite
    Infinite Member
    East Bay, CA
    My travels force me to drive a lot of economic rental cars and almost always I can plug my iPhone in a USB socket and play music right away without loss of quality over BT. The speakers on those cars do suck but that is not the point here. The point is what prevents Tesla from making this work? If cost was a constraint they can surely absorb that in the UHFS package cost.
  20. BertL
    BertL Active Member
    Carlsbad, CA
    Folks: We're going further off-topic here, as this thread is oriented to @majorlance's Applescript to assist with syncing tunes to a USB stick. I'd suggest there are better threads to discuss:
    TeslaTunes: Easy iTunes playlist syncing for Tesla USB flash drive
    Infotainment Issues, lack of features and wishlist:
