Eibach Pro-Kit
NikkoPh
MYLR | White | Black | 20s | 5seat | OD 6/8/21
Jun 19, 2021
58
101
SoCal
Lowered my MYLR with Eibach Pro-Kit, moderate drop at 1.1 front and 1.5 rear. Ride is stiffer, not bouncy and much more comfortable than stock. Took me and a few buddies 3 hours to install, really easy as long as you have the right tools.
Awesome! Been waiting on UPP for almost a year now. Just noticed they say Long Range. Sigh
How do you like it?
Edit:
Found the performance variant. Not as big drop thoughView attachment 743025
Right, i believe they are the same springs base on the part #. I like it, just the right stiffness, not bouncy at all.. perfect for daily driving
Reactions: Young Phenom
Just ordered a set today, looking forward to the slightly lowered stance!
I put on a set of Uberturbine take-offs from another forum member a few months ago. It’s painful to see the stock LR ride height when paired with the 21” OEM tire sizes.
After I install the springs, I’m going to take measurements and order spacers as well. I’m not planning on upsizing the tires, so I’ll likely go slightly more aggressive with the spacers.
If the OP doesn’t mind, I’ll post pics in this thread as things progress.
Here are some stock ground to fender measurements on our LR with Uberturbines. Quite a difference on the rear (~1/2”). First pic is drivers front, then drivers rear, passenger rear, and passenger front.
Closer pics of each measurement, same rotation:
Reactions: preilly44
Thanks for the photos, i should have done that in the first place. Front springs could use a little more drop to even the stance. Honestly its stiffer compared to stock but you dont really notice it until you hit bumps and uneven pavements.
Reactions: Simans82
