Those are about the same measurements my SR+ had. Definitely the exact same in front. Don’t remember on the rear. However my rear passenger side was also higher. Even after Installing Eibach springs and now with my MPP comfort coil overs. Still sits .25” higher on drivers side rear. At least now I can adjust it. MPP told me it wasn’t uncommon for the rear to be a bit off on these cars.Thanks @TypeRx
My stock OEM height is:
Right Front: 28 1/2" to ground
Left Front: 28 1/2" to ground
Right Rear: 28 3/4" to ground
Left Rear: 29" to ground
is there a reason why the left rear is 29"?? I was parked on a somewhat flat driveway.
I'm picking up my car soon that's getting the Eibach pro-kit. They're also doing an alignment on it. I'm just worried that my Tesla P3D+ seemed higher than others especially the rears and now that I've put on the springs they won't be as low like other Performance model 3's with the Eibach Pro-kit. Hopefully that makes sense. Anyone know what I can do about this?
Do the Eibach springs have a settling period? How long does that take and what exactly does that mean?
Mine didn’t settle. Sort of an urban myth. Put the car on the ground and drive 5 miles or so. Pretty much get what ya got.Do the Eibach springs have a settling period? How long does that take and what exactly does that mean?
Any of you P3D owners scrape with the Eibach drop? Any clearance issues with passengers? I want a mild drop that's fully functional and still driveable.
It’s so bad it has to be photoshopped.^^^WTF??? Haha, worst driveway ever
are you guys buying the sway bars, too? Figure for only $300 more you may as well add them while the cars on the lift. Any LR AWD folks recommend the sway bars or is that unnecessary?
To my eye, the eibach springs bring the model 3 down to a "shoudl've been stock" level and addresses the uneven front and rear. I had my heart set on the unplugged kit but their drops always look uneven
Just done with Eibach Pro springs as well - no spacers (plan on 20 mm Blox rear). No neg rake. I think photos with the bulbous greenhouse of the 3 makes it look like that. With darker tint, chrome and pillar delete, this visually lowers the top and helps some.
Before
Eibach
Due to the very slight angle differences of the shots, it doesn't look much different, but it certainly is. I measured 1" front and 1.3" rear. I also strangely found the ride actually smoother. Handled about the same to me (my weekend car a very low Porsche Boxter S I toss around with ease) around town. I'm sure at the limits or at speed it will be a bit better. Should help efficiency as well on the highway if anyone cares about that with the Performance model ;-)
Can definitely see the difference -- subtle on the front, very subtle on the rear -- but, the angle of your driveway and the photo make the drop look less than it actually is. Agree that the ride is somehow a bit smoother on normal pavement.
Did you trim your bump stops? Alignment after?
Ah, forgot those nuggets - I did NOT trim the bump stops (labored over this). I also did not do an alignment yet (seems fine) since I will give this a few months and possibly just go with coil overs. With this mild drop, I don't expect much is needed (and a slight neg camber is OK in my book). I don't plan on it though since this isn't my main "fun car" and it handles just fine for a daily driver.
