XLR82XS
D M C
Nice. Great minds think alike....Looks great. I am installing mine on Friday (17th)
Our cars are pretty much identical. lol
Is there any yearly maintenance one would have to do with springs? How long could you keep them on without having to fix it theoretically, especially if you dont take it to the track and do more of a twisty spirited drives? Would I have to adjust or do anything to it ever 1-2 years or something like that? Paging @DB-Cooper
No, there is no maintenance on springs, whether OEM or aftermarket. No adjustments, no fluid to change (LOL), nothing in particular to clean. Make sure they are installed/seated properly from the get go and that the bump stops are appropriately trimmed. Springs will likely outlive the effective life of the car...shocks on the other hand may require replacement at some point during its life.
So I've heard mix reviews, some say cut the bump stops, some warn not to. New to wheel/suspension stuff..what's the purpose of it?
How much would it cost to replace the shocks? what about struts? How would I know when to replace it? Every 5-10 years??
You can choose to trust the manufacturer who provides application-specific instructions and has engineers that literally obsess over things like this or you can trust advice from people on the Internet with anecdotal experience. One thing is certainly true -- if your suspension "bottoms out" and the shocks essentially rebound against the bump stop (which are basically acting as ultra high rate springs in this situation), your chance of blowing out the shock are higher than if there is a bit more clearance due to a trimmed bump stop. You may never "bottom out" but if you do drive/corner hard, hit a pothole or bump, etc., the risk is certainly there.
I would say the opposite of this is true. I would suspect the bump stops are there to protect the strut/shock from blowing out due to over compression.
Same as rwd. Just cut off the first rib (lobe) and that’s about 20mm or so off the overall length.
I've seen many Eibach pro-kit on Model 3 and some are a little bit lower than others. I suspect it could be from cutting the bump stops? Thats about half an inch lower if you cut of the bump stops.
That is probably due to differences in wheels or Performance vs Non-Performance.
Bump stops have absolutely nothing to do with the height of my car.
My installer refused to cut the bump stops saying he never does. I push led him to do it, but he wouldn’t. I’d trim them in the rear if I was doing it, but I wouldn’t lose sleep either way.
Hi Guys, I cannot speak highly enough of Eibach & the products they make. I got my Tesla Model 3 Performance lowered from them directly as they didn't have springs for the 2020 yet & used my car for R&D. These springs dropped the car I believe 1" up front & 1.4" in the back to create the perfect ride height & not give it that raked look. I was very skepticial to go the spring route as I was nervous ride quality would suffer but it honestly feels better than stock & doesn't feel like you are driving on a cloud. It is a lot more planted & handles perfectly. Here are a few images of my car, sorry for the side shot - it is using my iPhone & used the wide angle so makes it look a little different but overall very very happy with the product & ride. Hands down the best springs made & would absolutely reccomend them. Do not play around & go straight to Eibach, you will not be dissapointed!
They're not different. Eibach P/N is the same for 2018 - 2020. (I have Eibach pro-kit)Are you suggesting the 2020 springs are different? Are they out yet?
