If you want to get better longer screws get 4x M10x1.5x25 flanged, with 12mm heads.
Thanks for the specs! The factory service manually says to replace the nuts (front) and bolts (rear) anyway.
Installed mine today. Very easy quick install. So far so good. No noise, squeaks, far more neutral steering and a planted stance, especially while cornering or changing direction, providing steering input.
Unlike some from the competition, theae do not hit or rub anything when in any of the adjustment positions.
One thing to note, the rear sway bracket holding screws are a tad short (you reuse them). I let Eibach R&D and QA know already.
Best setting for normal 3-4 season street driving is Front Sway on medium street hole. Rear Sway on soft comfort hole.
View attachment 545667 View attachment 545668
Also the UP bar comes with a flange to stop the bar from sliding. Eibach doesnt.Just installed both bars and thank you for mentioning the longer bolts! This would've been a further pain putting this back on with the factory bolts.
The rear took me about an hour to put on as I did it in my driveway with a floor jack and stands. Whoever did it in 15 mins (somewhere on here) must be part of an F1 team or only did a '1 foot rollout' after the undertray was taken off and hoisted up. lol.
The fronts were a bit of a pain to install as you reuse the factory bushing bracket. Pressing it in and aligning it back when installing was some work. Maybe I was doing it wrong?! probably...
I chose the middle hole on the front and the firmest on the rear. The car to me delivers a more confident feel and doesn't have a quick twitch feel that I thought I would get by using the middle hole of the front. All in all a great upgrade over stock.
For a $200 difference the UP's might come with a new front bracket? makes the price difference seem not as distant. This did add 30 + minutes and a workout to the install process for me.
The flanges are unneccesary, but to each his/her own - UP, MPP, Eibach, whatever. SSDD.
The trick with the FSB OE bushings is to lube them a bit prior to removal from the brackets... for anyone who got them off, you probably noticed they have little notches formed into the rubber that clip into openings in the OE brackets. These help to lock and hold them in place.
Best to release them with a large flathead and they come out very easy.
The poly replacements (at least from Eibach but likely from any/all aftermarket companies) do not have those notches but do have the spine buldge that mates with the inner surface of the OE bracket.
Press them in as far as they will go and let the bracket hardware retorquing do the rest.
Here are the SS flange bolts I used on the back with the Eibach RSB. You need four of them to replace the stock (tad too short ones). These are the perfect length and fit.
M10x1.5x25 corse thread, M15 flange.
https://www.amazon.com/dp/B082TR1WS3?ref=ppx_pop_mob_ap_shareWhere did you find the bolts for sale?
sportcompactwarehouse.com
EIBACH E40-87-001-01-11 - bars
Installed my bars today...
I don't think so, it's just a consequence of the design. The UP bushings are "self-centering" since they have a lip on the sides. So it takes a bit more care to install the Eibachs. I accidentally installed the brackets on the wrong side; I swapped them while under the car, thus making my life even harder
That being said I like that the Eibach bushings are under a lot more load than the UP bushings. They have a tighter fit in the clamps, and more material to compress once you clamp them down.
I chose the same settings. I ran soft up front, middle in rear with the UP bars and wanted to try stiffening both ends. I like it better, especially in the rear.
By eye-ball measurement, I would say the two holes on the Eibach rear bar correspond to the middle and firm holes on the UP bar; I.e. the UP bar's third setting would be softer. Would be nice if Eibach just published the rates
The UP bars do *not* include front brackets. Also the rear brackets are steel on the UP set, not aluminum. The major difference in construction between the two is that the UP end tabs are welded, as well as the flanges. The Eibach bars appear to be press-welded? The point being the UP bars are probably a bit more expensive to produce (not $200 more though). Also the UP bars appear to have a more expensive paint finish, though mine arrived chipped in the box regardless.
The BMW issue is probably different though. I believe they use "stretch bolts" like VAG. Way more dangerous to reuse stretch bolts than locknuts. Not that it can't be done, just need to be more careful.
Yeah for something like this I would 100000% use new hardware. But for a part with some non-critical purpose.... meh.All bolts stretch when you torque them, it’s the ‘stretch’ that keeps them tight. It’s when they are overtightened and enter their plastic region that they need replacing, or when they have been tightened multiple times (cyclic load) so that their ultimate tensile strength is reduced and cracks may start to form.
This is normally only a problem with fasteners that are under extremely high stress, such as conrod bolts or head bolts on a high HP motor. Even the main bolts holding a turbofan engine to a B737 are reused after being cracked tested, and you’d be surprised how small they are, and how few there are!
