I realize this quote is from a previous post, but I think it sums up the discussion so far:
You guys...insist on using layman's though process to dismiss something that requires technical expertise.
On the flip side, bouncing between contextually unrelated nuggets of detail makes it difficult to identify the point you're actually trying to make. Doubly difficult is navigating through your points that support electric airplanes over conventional but don’t maintain any specific relevance to the regen conversation (which, near as I know, is the topic du jour…).
I think what this discussion really comes down to is speculation on the magnitude and value of the benefit from aircraft regen—which, to be sure, is a fun thought experiment and I applaud you for pursuing. From a first principals perspective though--an Elon-ey approach, if you will--one should be able to communicate even the most difficult concepts with fundamental concepts and a manageable word count.
Why are you talking about props when I'm talking about fans ? Aren't those very different from each other ?
From a first principals perspective, they’re the same thing: Lifting bodies in relative motion to an air mass, transferring energy to or from that air mass.
Props came into the discussion specifically with Large Ham’s contribution, and specifically since a company apparently thinks there’s a legit reason to have regen on their products…but as noted above its all the same thing anyway. The grey list of pros and cons for aircraft regen just shifts this way or that depending on whether you’re talking about a GA trainer or a long haul heavy.
Remember I'm not talking about regen as a means to stop the aircraft on the ground. Landing will likely expend energy rather than recover.
I’m not sure that logic closes. The landing roll of a would be one of the more straightforward places to implement aircraft regen. It’s really a basic equation: Plane lands with energy E, plane needs to dump E before the end of the runway. Only in a situation where the plane’s energy shunting systems can’t collectively convert enough of E to not crash at the end of the runway would you need to add even more [negative] energy to balance out the equation.
Regen applies to anywhere from full cruising speed to somewhat less than cruise, but still over half of cruising speed, still a LOT of airflow flowing through the fans to be decelerated.
It’s not obvious what you’re suggesting here, but I’ll assume you’re not making the “we should strap a windmill to the top of our Teslas” analogy.
Bottom line, any flight phase that is a net consumer of energy has
zero opportunity for regen. Basically the only phase that has
any opportunity for regen is descent [through landing], where—efficiency and practicality aside—you could theoretically trade speed and/or altitude for regenerated electrons. But, you still have the first principals problem of Lift=Weight and Thrust=Drag. There’s only so much energy you can take out of the system period, regardless if its through regen or some other form of energy shedding.
To be clear, I’m a fan of taking the perspective that opportunities>>roadblocks. ’m not trying to tell you that regen won’t work, I’m just trying to help you bound the regen possibilities.
@Etna has provided some detail on why a fan won’t regen well. From a more first principals perspective @Etna’s point is simply that, like most things in the universe, the air mass is going to take the path of least resistance. In the case of an aircraft engine that path happens to be mostly around the fan, not mostly through it. That goes for any phase of flight, by the way, including on the ground. In the top level energy equation, the drag component of an aircraft motor will likely be much higher than any realistic regen component.
Even so, from the thought experiment perspective I’m willing to throw a magical cloak of The Future over that and assume there’s some technology advancement to maximize energy recovery. And with that in mind, you could be on to something with the time component of flight. If, for instance, you could shave 5 minutes from the descent phase of every flight, what’s that worth? Even if it meant more overall energy consumption, would that be A Good Thing for aircraft? Possibly. If that energy was 100% electric, renewable, and effectively limitless? Likely.
Then again, the above 5 minute concept isn’t exclusive to electric engines. Current aircraft could easily cruise longer and descend faster, saving that 5 minutes, but they don’t. Consider why.
