NEM2 systems should be sized with an estimated annual production no larger than 110% of the Customer’s total previous 12 months of usage (annual usage) and projected future increase. All NEM2 customers must take service on a Time-of-Use rate schedule and sizing your system to offset 80%-85% of your average electricity usage could be an effective way to minimize your electricity bill .
Said should be. So, not seeing any teeth in their commentFrom PG&E form Form 79-1151A-02,
AGREEMENT AND CUSTOMER AUTHORIZATION
Net Energy Metering (NEM2) Interconnection
For Solar And/Or Wind Electric Generating
Facilities Of 30 Kilowatts Or Less
Yep, I know that. But this person was told if you go over a certain amount, you get zero further credit for energy sent back. I have never heard of thisIf you over produce on an annual basis, they are only going to pay you $.02/kWh, so it doesn't matter all that much.
Its possible to have a negative or zero NEM bill, but not over produce
With storage plus solar they calculate how much energy your solar could produce and limit you to that. I know this because on the record configuration is still messed up with PG&E when my Powerwalls were installed. They think I have a much solar solar system and I eventually noticed not all of my production was being credited. I've temporarily worked around the issue by switching to "balanced mode" so I'm self consuming more.
Well the reason you fill out the form is to make PG&E comfortable you will not exceed your production. According to my Tesla person it is their way of doing a pre - PTO and if you exceed it they will not approve the PTO. So Tesla makes this a check off for selling you solar. If PG&E objects Tesla will not sell you the system.
They think I have a smaller system. They think I have 2.9 kW when in actually have 13 kW. Somehow Tesla entered the wrong numbers in forms they sent to PG&E, I didn't notice at that time.Not quite understanding this. If they think you have a bigger system, then wouldn't you be under producing?
So, it is true. What was the data sent to PGE when you put the solar on relative to you use, % overage, etc. How did you see not all
your production was being credited?
wow, looks like I do not want to sent this page.
So, is this because of note above that 2.9KW system was submitted? From other comment, it seems that if a PTO is approved with the correct and agreed upon solar size, then would imply it would be impossible to get this over produced note?
How do you go about getting your information corrected?
With storage plus solar they calculate how much energy your solar could produce and limit you to that. I know this because on the record configuration is still messed up with PG&E when my Powerwalls were installed. They think I have a much *smaller* solar system and I eventually noticed not all of my production was being credited. I've temporarily worked around the issue by switching to "balanced mode" so I'm self consuming more.
I think you need to validate what you want to do. By default Tesla assumes you are going to be applying for the Solar ITC with your Powerwalls. Therefore you can only export solar energy while it is being produced. You can use solar energy that you "banked" in your PWs during a time that you would not have gotten the best rate for them, and then use that power during peak periods.Interesting because my system is sized to produce just about what I consume but with my 3 powerwalls, I'll be sending all of my peak production back to the grid while I'm 100% powered from the batteries during those hours. Without the time shifting, my 8.16kw system would have to be more than double to get the same credits I'm planning on getting. i.e I intent to use more energy than I used to by quite a bit because I can sell expensive and buy cheap. I intend to run my AC more than 300% more during the summer than any previous year and only pay the $10 minimum billable + 2 cents per kwh of NBCs consumed off the grid(my penalty for not running in self consumption mode as much as possible).
Hopefully that rule is based on kwh produced and not WHEN those kwh are put back on the grid.
And when do you lose the overproduction if you exceed the 110%? Every month or only at true-up. i.e. if does it only result in lose of overproduced energy at wholesale prices or do they just stop crediting you part way through the year once you've put too much energy back onto the grid?
The limitation in the ITC is that the batteries have to be charged by solar a certain amount of the time. Tesla's assumption and programming insures that any Powerwalls connected to solar can only be charged from solar. The only exception are events that presumably do not happen frequently enough to go beyond the limitations of the rule.I think you need to validate what you want to do. By default Tesla assumes you are going to be applying for the Solar ITC with your Powerwalls. Therefore you can only export solar energy while it is being produced.
I would love to see how he plans to make it work.I think you need to validate what you want to do. By default Tesla assumes you are going to be applying for the Solar ITC with your Powerwalls. Therefore you can only export solar energy while it is being produced. You can use solar energy that you "banked" in your PWs during a time that you would not have gotten the best rate for them, and then use that power during peak periods.
But you cannot "sell expensive and buy cheap". You cannot buy any power (except during Storm Watch events) that is stored in the PWs.
It sounds like you want to run the PWs in Custom - Cost Savings mode so look into the details on how that works.
But you cannot "sell expensive and buy cheap". You cannot buy any power (except during Storm Watch events) that is stored in the PWs..
