AlanSubie4Life
Efficiency Obsessed Member
I think if we knew what was actually happening under the hood, we might be more impressed with the feature.
Well, once it runs into something, we'll be able to see under the hood. Then we'll know.
You are talking about the static world. In the AI interview with George Hotz, he explains this well.
- Static world
- Dynamic world, where lots of actors are moving and you have to predict their behavior
- your action is going to change the way the various actors are going to change their behavior and you have to predict the changes depending on your choices
Do you think that's true on an E[Property Value Loss] per use basis? I'm not sure, even though I am only going by videos of Enhanced Summon at this point.
Could we use that as a metric for suckage?
If this were the case Waymo would be at L5 by now. You write down the rules and then we'll talk about whether it's trivial or not. When the best minds in the industry say it's the most difficult part it is weird that you dismis it as trivial.If the NN plus sensor HW could identify all objects like a human can, I’m convinced that the route planning task, even if objects move dynamically, is comparatively trivial.
Well, it is easy to be safe when the feature doesn't really do anything. Sure, the current summon is super safe but that is because it doesn't really do anything. It can only creep forward and backwards a few feet.
Of course, with increased capability does come extra risk.
But that is why Tesla needs to be more careful in releasing Enhanced Summon.
The reason why nobody has L5 out there is because there is no sensor plus computer system in existence on this planet that can detect all objects with the required precision to guaratee safe operation.
It’s not because they didn’t figure out how to navigate around that.
You mix up challenging vision problems with driving rules.
I don't know your background - but if you read up / listen to the podcasts / see relevant you tube videos you will figure out this is not the case at all.It’s not because they didn’t figure out how to navigate around that.
And the car still manages to hit things on regular summon before people can react in time to stop it. That is just based on the number of "Summom hit my garage before I could stop it!" posts I have seen here and elsewhere. That may just be user knowledge issues (not knowing that you can abort by pressing a door handle even if the app stopped responding mid-summon). But super safe summon still hits stuff.
I can imagine the number of things the car manages to hit on enhanced summon will be enhanced exponentially.
Now that I think about it, an empty car silently backing out of a parking space could really be a safety hazard for pedestrians in the area. (And you know everyone who uses summon to pick themselves up from the curb is not going to doublecheck for pedestrians at the car.) Hopefully the car will be really, really, really good at seeing them with the current sensors.
You can use smart summon for this !Or a better summons that could be trained on a specific route. Most people are going to want to summons with a very specific motion. Like I'd love to summons my car from one spot to the spot over so I can pull my other car out of the garage.
Very doubtful. If it is annoyingly slow, people won't use it in busy parking lots. Like someone posted (reddit ?), it is good for work paking lots, which generally have light traffic.As to enhanced summons I think it's biggest issue won't be hitting things, but being so massively annoying to other drivers that fights will break out.
One of the things I find frustrating about enhanced summons is it feels like they skipped a step.
Regular summons and regular self park are limited to using just the ultrasonics, and those are obviously pretty blind as a results.
But, instead of trying to improve those by aiding vision they immediately jumped to working on enhanced summons to go clear across a parking lot. I think they would have been better off with a much more incremental approach.
Things like making auto park better by taking advantage of the cameras, and getting rid of the limitations on needing to have cars on both sides while reverse parking.
No, it is not difficult. It is easy.But enhanced summon is difficult..
Yes. Waymo has been writing code for ten years and it is not yet ready. So it is definately not trivial. If it would be trivial, with Google's resourses and ten years, it would be ready.If this were the case Waymo would be at L5 by now. You write down the rules and then we'll talk about whether it's trivial or not. When the best minds in the industry say it's the most difficult part it is weird that you dismis it as trivial.
I don't think you are correct. Waymo cars with their 360 degree lidar, cameras and radar should definitely be able to see all objects around the car with very high precision. The problem is in fact driving rules, not vision. While they actually can see all objects with very high precision, they can't always anticipate what the objects will do. That's the problem. Knowing where all objects are around the car is only half the battle. The tricky part is writing the driving policies to handle all the edge cases of what the objects may do. That is what is currently holding up companies like waymo from getting to L5, not vision.
How will L5 ever work in bad weather, when you would want it most?
Seems like the focus is more on releasing more parlor tricks/gimmicks than perfecting prior releases (turning prior parlor tricks/gimmicks into reliable, functional features).
Actually it allready works
Uh?! The whole point of enhanced summon is to turn a parlor trick (current summon) into something more useful and functional (navigating a parking lot).
