Error code chatter in vehicle logs
Discussion in 'Roadster: Technical' started by jeremyz, Nov 7, 2013.
  1. jeremyz
    jeremyz Member
    Is it normal for the Roadster to intermittently throw out error codes? I don't think the errors are that critical since none of the errors map to any known errors that I've found (although it doesn't seem like many error codes have been mapped).
    Here's an example of what I'm talking about:
    1: error count for month
    2: histogram of error count
    3: List of 3 most common errors with count and error code number
    date 1 2 3
    2010_03: 12 ### 3 error_65535, 3 error_19, 1 error_955
    2010_04: 17 #### 10 error_19, 1 error_925, 1 error_1660
    2010_05: 12 ### 3 error_934, 2 error_415, 2 error_925
    2010_06: 22 ##### 7 error_925, 4 error_264, 3 error_283
    2010_07: 12 ### 9 error_925, 2 error_934, 1 error_1418
    2010_08: 59 ############ 46 error_415, 3 error_925, 3 error_955
    2010_09: 28 ###### 7 error_934, 4 error_65535, 4 error_2
    2010_10: 5 # 5 error_65535, ,
    2010_11: 7 ## 2 error_65535, 2 error_414, 2 error_415
    2010_12: 12 ### 7 error_50, 3 error_1, 1 error_57
    2011_03: 7 ## 4 error_415, 1 error_934, 1 error_65535
    2011_04: 20 #### 9 error_19, 7 error_65535, 2 error_934
    2011_05: 10 ## 5 error_934, 4 error_65535, 1 error_925
    2011_06: 80 ################ 17 error_1, 8 error_1533, 5 error_415
    2011_07: 39 ######## 31 error_925, 2 error_934, 2 error_65535
    2011_08: 26 ###### 11 error_925, 6 error_934, 2 error_955
    2011_09: 10 ## 5 error_934, 4 error_925, 1 error_65535
    2011_10: 5 # 2 error_65535, 2 error_415, 1 error_934
    2011_11: 5 # 3 error_955, 2 error_65535,
  2. jeremyz
    jeremyz Member
    I guess the heart of my question is whether or not most of the reported errors are actually errors or if they are just warnings. The "errors" that I see that have text descriptions are just warnings about the tire pressure.
  3. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    List of known codes vs messages is here:
    Open-Vehicle-Monitoring-System/server/ovms_server_tr.vece at master · markwj/Open-Vehicle-Monitoring-System · GitHub
    The ones prefixed DMC are debug messages and, we are told, not to be generally worried about.
    65535 is the code to clear the error (on the can bus at least), so I suspect not a worry for you.
  4. thefortunes
    thefortunes Active Member
    Wisconsin
    I can add a few more to the knowledge base:
    1095 Press brake pedal before shift
    1160 Drivers door ajar
    1162 Trunk ajar
    1167 Headlights on (I don't recall the circumstances)
  5. markwj
    Hong Kong
    Thanks. I've added them, and will commit to github later.
    P.S. Apart from 1167. I think it better to get the exact error message for that (because 'headlights on' does not really make sense as an error).
  6. jeremyz
    jeremyz Member
    Thanks. You have some more error codes than what I was able to find. From inference, I think I figured out what codes 1075, 1076 and 1077 are
    1075=DMC FW: PhaseB OverTemp warning. Torque limited
    1076=DMC FW: PhaseB Temp Diff warning
    1077=DMC FW: PhaseC OverTemp warning. Torque limited
  7. djp
    djp Model 3 Performance
    Toronto, Canada
    I've occasionally seen "Headlights on" come up as an error badge on the VDS when starting the car. Yes, that is the actual text but I have no idea why it's considered an error. I've always just ignored it.
  8. jeremyz
    jeremyz Member
    Does anybody know how worrisome these faults are?
    BSM: Isolation fault
    BSM: Isolation fault while contactors closed
  9. jbadger
    jbadger TR#506, 3#1206
    San Jose, California, United States
    I've seen the "headlights on" error before, and you're right, it makes no sense. I had just turned the car on and it immediately gave me that error.
    Also, here is one I notice you do not have.
    ID: 529 - Check right low beam bulb
  10. djp
    Toronto, Canada
    #10 djp, Nov 11, 2013
    Here are a couple more:
    538 Check left front signal indicator bulb
    539 Check right front signal indicator bulb
  11. thefortunes
    Wisconsin
    These were errors I got when my heater box needed to be replaced. Apparently there was some moisture getting in (or to a part) that was causing an isolation error. After seeing it a couple times after/during rain and being able to clear it by running the heater (per Tesla recommendation) it finally got to the point where it wouldn't clear and the car wouldn't charge.
