Got it. If I understand it, the limit is applied month by month, is an estimate of the maximum amount your solar could produce, and the result is shown on the black&white bill pages. So if they have the right total size of your solar, you should be OK. I don't think they take actual weather or shading into account, just the season adjusted sun, panel specs, orientation and tilt, and inverter efficiency, if memory serves. Any self consumption, shade, clouds and such will reduce your production, but not PG&E's monthly estimate and limit, if I understand it correctly. So these give you some margin. As long as your export for the month is less than their estimate, the limit is moot.
Where one might get a reduced credit would be if more solar was added but PG&E not informed. Still self consumption would give breathing room.
PG&E will send you a copy of anything your installer gave them, and some of it may be accessible to you online. Installers fill out the paperwork and submit it on your behalf, so you may not have ever seen the actual documents which give the panel model numbers and orientations. There is a database of all the panel and inverter models which gives the specs. So unless your installer fudged on the forms, PG&E should have a pretty good basis for their estimations.
In my case, I have plenty of self generation, so I've never exported near the limit. Your system being much larger might get closer, but still if they've got good data, you should be fine.
As I understand it, the only point of the limit is to ensure that you are not grid charging off peak, and discharging to the grid at peak. This whole limitation thing is because you have storage and could, conceivably, cheat. Remember that PG&E gets a regulated profit based on their expenses, so being paranoid and doing all that extra paperwork to be sure you don't cheat simply makes them money.
SW
