Since we hadn't seen any posted, we decided to make our own model 3 Dyno video. Absolutely amazed by this car. It will change the world.
Tesla is absolutely sand bagging this car. From 30mph rolls, we were getting consistent 250hp range pulls (you can see it in the TV during the calibration run). Once we dropped the speed down below 15mph, the horsepower jumped considerably.Very interesting. If it’s correct, Tesla is advertising the HP at it’s top speed and not its actual peak HP.
Thanks for doing this. I’m looking forward to thoughts and comments from others.
It does do better than 5.1. There's been tests of it at around 4.5 to 60.Actually, I’m not sure what this is showing. Does the stock Model 3 LR put out 393+ HP, or is Tesla limiting it to less than that? Shouldn’t a roughly 400 HP, 3800 lb car do better than 5.1 sec from 0-60 mph?
I'm on a slowish Internet connection so the video may be fuzzier than you uploaded.
So what speed was that max HP at? I'm guessing from the blobs on the bottom axis it was either somewhere near 65mph, or am I "reading" that wrong?
We fully defeated itMy gas rear drive 4000 lb car with 410 dynoed at the rear wheels did 0-60 in 4.5 sec with traction control off. BUT the launch had to be perfect to prevent wheelspin or it was 5 sec. So the 3 at 3800 lb. doing it 4.7 to 4.9 seems reasonable at 390 hp with traction control that’s not fully defeatable.
Oddly enough, that's almost exactly where the P85 peaks at, as well.The HP peak is right around 68 MPH.
What do you mean by this?Tesla is absolutely sand bagging this car. From 30mph rolls, we were getting consistent 250hp range pulls (you can see it in the TV during the calibration run). Once we dropped the speed down below 15mph, the horsepower jumped considerably.
