Express Lanes and FasTrak
Discussion in 'Model S' started by joebiker25, Sep 9, 2016.
Tags:
  1. joebiker25
    joebiker25 Member
    SF Bay Area, CA
    Do you need a FasTrak tag/account to solo drive your stickered EV on I-580 and I-680 Express lanes?
    Thanks!
  2. silentsnow31802
    Napa, Ca
    FasTrak
    Am I Toll-Exempt | Bay Area Express Lane
    I was just looking into this a couple days ago. It seems you do not need a tag/account on I-680 since you do not want it charging you anyways. However you EV must have a white or green sticker to use the express lane.
    It also seems you NEED a Fastrak tag/account to use the I-580 lane. A Flex tag to be exact.
    Either way those two links should answer any questions you have on the subject.
  3. joebiker25
    joebiker25 Member
    SF Bay Area, CA
    Thanks so much silentsnow31802!!!
  4. SoccerMan94043
    San Jose
    Just get a fast track toll tag, set it to three+, stick it under your trunk parcel shelf and forget it.
    FasTrak
  5. JPP
    JPP Active Member
    SF Bay Area, CA
    You need the Flex transponder. Just leave it set to 3 as SoccerMan notes. FWIW instead of mounting it under the parcel shelf (which I sometimes move/remove), I have mounted it in the center of the rear lift gate window at the bottom edge. It then is not in the line of sight from the inside rear view mirror.
  6. joebiker25
    joebiker25 Member
    SF Bay Area, CA
    Perfect! I rarely use I-580 during commute hours but will get a FasTrak transponder just in case.
  7. TR5642
    TR5642 Member
    California - SF Bay Area
    Do I read correctly that you are using the transponder in the rear of the car? (either under the shelf or on rear window?) Does it work reliably there? Trying to find a spot on the windshield is driving me nuts. I've taken to holding it out the sunroof :-(
  8. JPP
    JPP Active Member
    SF Bay Area, CA
    Yes. my wife's 2015 S70D does not have any RF 'window' in the front windshield. I even tried the pano roof. I have mounted it centered in the rear liftgate window at the bottom edge. When looking from the inside front (through the rear view mirror) it is fully obscured by the tall middle seat headrest. Works 100% of the time with the current generation FasTrak Flex rectangular switched toll transponder in landscape position. FWIW, since her car is black, and the interior is black, I took black electrical tape and wrapped the whole thing, and substituted black Velcro for the white stuff. It basically disappears when looking from outside in.
  9. SoccerMan94043
    San Jose
    I've only been charged twice, going through the Bay Bridge toll. Both times worked when mounted under the center of the parcel shelf. There is a thread on the mounting placement somewhere around this site.
  10. JPP
    JPP Active Member
    SF Bay Area, CA
    This works as well, as long as you don't need to remove your parcel shelf and leave it at home....
  11. silentsnow31802
    Napa, Ca
    I have mine under the parcel shelf in the center. You can only see it if you lift the shelf up. Out of my last 13 transactions it only missed the transponder once.
  12. TMobe
    TMobe I have forgotten more than I remember
    Sacramento, California
    Am I reading it wrong? I thought it read you do not need a transponder at all?
    Bay Area Express Lanes Toll Tag Rules for Toll-Exempt Vehicles
    • No FasTrak® tag is needed to travel free in express lanes that are open today.
    • If you have a FasTrak tag in your vehicle, store it in the Mylar bag provided by FasTrak to avoid being charged in express lanes.
  13. joebiker25
    joebiker25 Member
    SF Bay Area, CA
    You need it for I-580;
    • A FasTrak Flex® tag is required to travel toll-free on the I-580 Express Lanes.
  14. JPP
    JPP Active Member
    SF Bay Area, CA
    ...and in a Tesla with the white HOV stickers, just leave the Flex transponder switch in position 3, for carpools and qualifying vehicles.
  15. Wuggado?
    Wuggado? Member
    East Bay Area, CA
    Not quite so easy. On I-680 if you have a transponder outside of the mylar it will read it and charge you. The I-680 lanes do not have the Flex hardware, so they don't know if you are using the lane as a carpooler or not. Thus the charge. As already mentioned, you have to have the Flex on I-580 to use the lanes and not get charged.
  16. silentsnow31802
    Napa, Ca
    This is exactly what I do. No need to worry about being charged when using express lanes. Toll booths still charge though. This is normal.
  17. m6bigdog
    m6bigdog Member
    San Ramon, CA
    Not Exactly,
    I -680 Sunol does have FasTrak Flex Hardware as per their current FAQ: Also, I have been using a FasTrak Flex Toll Tag set to 3+ since 2015 with no Express Lane usage charges.
    FAQ states:
    I-680 Sunol Express Lanes
    Located along a 14-mile stretch of southbound I-680 from State Route 84 south of Pleasanton to State Route 237 in Milpitas, the I-680 Sunol Southbound Express Lane has been in operation since September 2010. A northbound express lane along this same corridor is in the environmental documentation phase and is expected to begin construction in late 2017.
    WHEN DO THEY OPERATE?
    The I-680 Express Lanes operate Monday - Friday 5 a.m. - 8 p.m.
    Outside of these hours, the lanes are open to all vehicles at no charge.
    WHO CAN TRAVEL IN THE I-680 EXPRESS LANE?
    • Solo Driver with a valid FasTrak account may pay a toll to travel
      • May carry a FasTrak Flex toll tag set to 1, or
      • May carry a standard FasTrak or bumper tag
    • Carpools, Clean Air Vehicles with qualifying DMV sticker, Motorcycles, and Transit vehicles may travel toll free under the following conditions:
      • No toll tag in the vehicle (none required)
      • Standard FasTrak toll tag placed in mylar bag
      • FasTrak Flex tag set to 2 or 3+. FasTrak Flex has a switch that allows drivers to designate whether they are driving solo, or are a carpool with 2 or 3+.
