ElectricNerd
Only on a Model S or X right?What does "service" mean here? Is that installation?
Thanks for doing the leg-work for us. At least we have a realistic ballpark number for the price.It changes the XM station on MCU by voice command. 100% getting XM from antennae not WiFi streaming.
Heard back from a Tesla rep and got this msg
1143716-00-C : not available
1143711-00-C: not available
1622932-00-B = radio tuner AVAILABLE for $225 plus service
Utopia radio is a XM channel.Thanks for doing the leg-work for us. At least we have a realistic ballpark number for the price.
In the photo you uploaded it shows the streaming icon and "Utopia Radio." It's not showing the SiriusXM channel playing so that is why I asked.
Actually I took a look at both photos and 1 is showing XM icon and another shows streaming icon. Now I'm confused, could the tuner possibly enable wifi streaming???Thanks for doing the leg-work for us. At least we have a realistic ballpark number for the price.
I've been running my OEM Tesla tuner (without audio form the OEM tuner) along with my FM modulator tuner for not quite a month now. I'll tune both the OEM and FM modulator tuners to the same channel so I get both the text (artist/song) as well as the audio as a workaround until the OEM Tesla Tuner works completely.View attachment 833490
Did the icon change in an update or something? I'm truly confused now.
So you have a stand alone XM tuner?I've been running my OEM Tesla tuner (without audio form the OEM tuner) along with my FM modulator tuner for not quite a month now. I'll tune both the OEM and FM modulator tuners to the same channel so I get both the text (artist/song) as well as the audio as a workaround until the OEM Tesla Tuner works completely.
The channel icon will change from time to time. I assumed it was artwork built into the software, but it will even change for specific songs on the Chill channel for example. I don't currently have a Tesla Premium mobile subscription, nor do I have wifi enabled.
Stand alone XM tuner = FM modulator XM tuner.What are we calling a stand alone XM tuner?
My 2022 M3 LR has TWO tuners in it currently.
1. OEM Tesla XM Tuner which does everything but the audio (Currently on 3 month free trial sub)
2. FM modulator XM Tuner that audio comes through on an FM radio station. (Currently holding my lifetime sub)
Since the problem with my current setup is that the last FM tuned station comes through, I have the effect of it fully working, I just have to change the channel twice. Once on the #1 tuner through the MCU LCD interface and then again on #2 tuner through an IR remote. I don't like this, but its a workaround trying for the full solution of a single OEM Tesla XM tuner working.
From "very strange XM behavior" postYour X is getting the actual radio signal via the satellite. However, it does get channel listing and frequency via LTE for some reason. So, if you lose LTE service and were already listening to it, it will continue to play. But if you were on streaming, and try to switch to SXM, it won't load, because it needs the LTE signal to find the frequency or something. Not 100% sure on the exact technical details.
I can't say for sure as I have not seen your garage -- but with the past 4 cars I've had, I've always had SXM signal even when backing my car in, so the antenna is all the way in -- even with garage door closed, and no line of sight. And yet, I go under a bridge or a tree, and it cuts out... no clue how/why.
Might be a stupid question as I will attempt the install this weekend, but how easy is it to access the Model 3 FM tuner. I can see that we need to remove the panel on the passenger side on top of the trunk, but is there any video you guys have watched in order to do it the proper way? Thanks
So do you have 2 XM antenna?
its fairly simple. there are like 4 pieces you need to remove, which are all head in by clipsMight be a stupid question as I will attempt the install this weekend, but how easy is it to access the Model 3 FM tuner. I can see that we need to remove the panel on the passenger side on top of the trunk, but is there any video you guys have watched in order to do it the proper way? Thanks
where do you get these diagrams?Unfortunately not. I kind of just wiggled my fingers in the top and yanked down. The service manual shows push clips???
This applies to the right-hand side too. Maybe they're just push clips because you can just push it in; I have no idea how you release them from the outside.
