This photo was posted at 8:57AM Dec 26 on twitter by @ECDiazdeLeon who tweeted “We got a sneak peek at @SpaceX #FalconHeavy rocket while taking the bus tour. #SpaceX ”
I suppose that is possible but would guess that it will all depend on if any issues are found, first with the pad fit check, and then with the static fires. I’m sure that SpaceX will take their time analyzing the data from the static fires. They want to do everything they can to avoid a RUD.Did you notice in the twitter conversation that Chris B. thinks a mid Jan launch looks to be a reasonable prediction.
Earth to Mars and https://en.wikipedia.org/wiki/Exploration_of_Mars#Launch_windows
Optimal tx to mars centers around an April/May 2018 Launch. Still not bad if they do Jan 2018, just takes a little longer to get there and since the roadster doesn't need life support the travel time isn't an issue.
My understanding is that it will not orbit Mars, but will have an orbit that crosses Mars'.
It will not orbit mars but that doesn't change the transit time/deltav window concept if they want it to be a mars test flight. I'm assuming they'll go for a just short of capture hohman transfer and thus the difference in time/deltav will be pretty much spot on (they'll just aim to miss every so slightly instead of trying to hit a spot ideal for entering orbit). The table in post #14 that I linked to has the dV separated between leaving earth and entering orbit at Mars. I didn't include the entering orbit portion in my comparison.
Gotcha, Mavrick is going to request a fly-by and buzz the tower. That sounds much more interesting.
Launch window to mars is open once in two years. Launch window for Roadster is open always, because it goes close to orbit of Mars. It does not need to meet Mars there. They cannot do orbit insertion burn, because they cannot keep LOX from boiling away.It will not orbit mars but that doesn't change the transit time/deltav window concept if they want it to be a mars test flight. I'm assuming they'll go for a just short of capture hohman transfer and thus the difference in time/deltav will be pretty much spot on (they'll just aim to miss every so slightly instead of trying to hit a spot ideal for entering orbit). The table in post #14 that I linked to has the dV separated between leaving earth and entering orbit at Mars. I didn't include the entering orbit portion in my comparison.
The fact that they won't have to burn to enter orbit of mars and don't have to have any sort of lander or useful cargo keeps the dV requirement lower but you still need to get to the orbit of mars (not to be confused with mars orbit)
* orbit of mars (the distance from the sun that mars orbits at)
* mars orbit (a circle around the planet that a satellite would follow)
It will get to the orbit of mars, it just won't orbit mars.
"Time lapse of the rocket being erected.
Falcon Heavy goes vertical at launch pad 39A on December 28, 2017. The video runs at 34 times normal speed
https://player.vimeo.com/video/248983328
With help from google:"
Sorry
Because of its privacy settings, this video cannot be played here."
Roadster cannot take pictures of Mars so I don't see any reason to get close to Mars. They can measure its orbit and verify it is correct transfer orbit to Mars. Hohmann orbit with target close to Mars limits launch window. If you want to launch outside launch window you have to forget Hohmann or meeting with Mars. FH probably has fuel for non Hohmann transfer orbit, but why would they do that?That assumes SpaceX has no desire to get it close. Even without an insertion burn it could be guided near Mars just to say they did (just outside the gravity well).
I expect they have a target distance from Mars they want to hit and will have some way to track it to show it did go the desired route.
Always expect Elon to take it to the next level. He won't just put it in orbit of the sun and say it's good enough even if it never got anywhere near mars.
