Status? 99.99% of the population will not be able to see or understand the differences between the different flavors of the truck.
Who is so silly to think a 3 second pickup is important for 100,000 purchasers? A few sure, just like the people who a snow plow on the front of a Porsche.
I like the idea of a CT model doing 2.9 sec 0-60 mph but IMO that kind of acceleration is only fun if vehicle has sports car handling characteristics to match. I think the dual motor version will be the sweet spot for price/performance, especially if they $10k tax credit kicks in.
100,000? So about 10% of buyers? Maybe.
I did and that’s why I installed a 400A service for my home. Hopefully they offer an 80A charger for theNo body foresaw we would want to use electricity other than lights.
I do as well on my X. They need at least a 72A charger on the tri-motor.I think most of slow charging advocates miss the point. People are not buying 150-200 kWh batteries because they drive 10 miles to work.
They are towing, going to cabins with no/minimal power, to trailheads far away from any Superchargers, traveling a lot in very cold locations, etc.
A nominal 500 mile range will be less than 250 miles towing a big trailer in cold weather, assuming flat terrain. Higher speed AC charging will be mportant.
The 500 mile CT is not for urban cowboys going to the mall. The short range trucks, sure.
I can’t wait for my CT. I use the 72 A charging on my X all the time. Important for midday charging when needed.
Neither of these is going to happen. That ship sailed when Tesla moved their wall connectors to lower power versions that will only do 48A. Sorry. Tesla doesn't believe in higher power onboard chargers anymore. They think there is enough Supercharger coverage that people should just use that if they need anything faster than 48A AC charging.Hopefully they offer an 80A charger for the
Tri-motor. [...] I do as well on my X. They need at least a 72A charger on the tri-motor.
Rocky, you are often right but I hope you’re wrong on this.Neither of these is going to happen. That ship sailed when Tesla moved their wall connectors to lower power versions that will only do 48A. Sorry. Tesla doesn't believe in higher power onboard chargers anymore. They think there is enough Supercharger coverage that people should just use that if they need anything faster than 48A AC charging.
Higher than 48 amps starts to get real impractical for most residential electrical systems...
Not really. 200A is standard now. The bulk of that capacity is usually resistive heating. Replace that with a heat pump and you'll have more than enough capacity for 80A of charging. AND... Tesla already has a system for monitoring energy use... couple a 80A charger with a way to cutback charge rate when other loads increase and you'll have plenty of capacity.
well, you can only use 160 of the 200.
Also your suggesting it might be possible maybe if people replaced their central heating.
AKA not practical
??? I've never seen a situation where it wasn't only possible but economic. Resistive heating is absurdly inefficient. And as I said... add in demand control and you're set. Let's say someone has a $600/mo electric bill. Pretty high... yeah? That's on average ~35A.
Are tankless electric water heaters and resistive backup heat also 'not practical'. They also pull ~80A.
How well to heat pumps work below 40 degrees? Whose going to pay for the $10,000 upgrade to replace the unit?
with a demand control, what do you plan on shutting off? The heat or the car charger?
Sure. It's already frustrating to a lot of Tesla owners and will continue to frustrate more.Owners of cars with 150 to 200 kWh batteries, like Roadster 2 and tri motor CT don’t want to take 24 hours to fully recharge.
I'm certain they will not. They will say "Use Superchargers."I think they will reintroduce a higher charger for those two vehicles.
Sure, and there are a lot of Samsung Galaxy S6 phones still around too. They are old and orphaned as well.There are a lot of the 80 amp v.2 chargers around - I have two.
You can keep bringing up these edge cases, but Tesla is stating very explicitly that they are writing off those edge cases to go for the majority cases. I'm not denying that is going to be frustrating for some people in some situations. It certainly will, but that is what Tesla has decided on.A tradesman using the 50 amp receptacle or fast sports car on the track or showing off will need a lot of charging and SC just won’t be convenient at all.
I get frustrated visiting family, arriving late and only having a 14-50 to charger, and I have to leave for work/errands early the next morning without a full charge.
It will be worse with the CT and towing.
. Modern heat pumps work fine below 40F.
..... the charge rate of the car is reduced... obviously.
Modern heat pumps work fine below 40F. Whoever wants to charge their car at 80A and reduce their electric bill by ~50% will pay for their heat pump... obviously...
so now we aren’t doing a simple relay demand control we are setting up a networked system. How much money will that cost lol.
not really. They aren’t efficient under 40 degrees. And you’re ignoring the main problem.
Are you gonna give everyone 12000 dollars so they can get a heat pump and power management installed so they can charge their car only a little faster???? No... not networked.... simple CTs on the main lines. 160A max. HPWC ensures 160A is never exceeded... which is rarely would be. Simple. Do you have any clue how much 160A is? It's A LOT. The peak current draw for my house is maybe ~40A. This gets even easier if someone already has a PW Gateway...
Even when cold a heat pump still uses ~half as much energy as resistive heating. If you had 20kW of resistive heating you now how ~10kW freed up for more EV charging. If you had enough for 11kW before you now have 21kW.... math.
