On a daily basis, is it better to fill to 100%, or drain to 10%?
Details:
98 mile commute, each way, daily, plus minor errands.
Home charger, no work charger.
Thus needing 80%-90% nightly charge (weeknights).
(2019 Model 3, long-range)
The biggest problem with 100% charging is letting is sit that way, if you can charge to 100% and then drive it right away you should be fine. A better solution would be a way to charge in the middle of your commute. Even 15 minutes at a SC would help.
Sitting at either high or low is hard on the battery as Dsvick says. Charging to 90% is normal (and actually recommended unless you only drive ten miles a day or so, in which case 80% is better). With an LR 98 miles each way shouldn't be an issue. Draining low isn't so good because for a given amount of power, the battery heats up more when the state of charge is low.
@jerry33
If I charge to 90%, the battery is at 10%-15% at end of day.
I'm wondering if I should charge to 100% and thus end the day at over 20%, or charge to 90% as done currently.
thx
@jerry33
thx
If you can time it so that it's full or close to full at the time you start driving do that. Otherwise set it at just below 100% (95%). Or you could reduce speed by about 5 mph. It would make almost no difference in the commute time and would decrease energy usage by quite a bit.
Details:
