First Long Distance Road Trip
Discussion in 'Model Y: Driving Dynamics' started by Techie-HEX, Jan 9, 2021.
  1. Techie-HEX
    Techie-HEX Member
    PA
    I just completed my first long distance road trip with my Model Y. We traveled 1,200 miles from PA to FL. The car performed perfectly and I was glad to have Autopilot for the long drive down RT95. It does take some of the stress out of a long drive. Being new to an EV I had range anxiety so I planned on doing more recharge stops than the Tesla navigation calculated. I used Plug Share to break the trip down in 3 legs, 3 days of driving with 2 overnights. My goal was to come into a supercharger with no less than 40% battery remaining. I used the Tesla navigation to navigate from one supercharger to the next. I was pleased with the battery range especially on the first day in cold temps leaving PA. I did pre-warm the battery and cabin with my home charger before leaving. All of the superchargers worked fine although charging speed varied. I didn’t realize charging speed slows down as the battery reaches 80%. I have seen the KW drop from 130KW to 10KW as the battery filled. I did all of the charging at Tesla superchargers. I tried to select 250KW chargers and hotels located next to superchargers. Some hotels do have free destination chargers but I found it was better to find a good hotel rate versus paying a premium just because they have a 10KW charger. Total charging cost for the trip was $80.15. Comparatively the prior year I did this trip with my Acura MDX using premium fuel and it cost $145.
    • Like x 5
    • Informative x 3
  2. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    40%?! I'd target 10%. faster to charger. less stops.
    • Like x 5
  3. Techie-HEX
    Techie-HEX Member
    PA
    All that is true but my fear was getting to a supercharger with 10% and there was a problem with the charger. No options left to go to the next one. I am feeing more confident now that I visited all those chargers and there were no problems. We made the best use of the stops by making sure there were food and restroom options.
  4. GregW
    GregW Member
    La Jolla, Ca
    After 5 years and many, many road trips I've never had a problem with a Supercharger where all stalls were inoperative. Yes, I have heard of this, but extremely rare. The Nav should also show this rarity before you arrive. Now 1 or 2 stalls may not function well, usually can just switch stalls.
  5. jpfive
    jpfive Supporting Member
    Pensacola, FL
    I took the same cautious approach on my first long trip. Both normal and reasonable IMO. That first trip built the confidence for the several that I have taken since. Glad you had an enjoyable and relaxing trip.
    • Like x 4
  6. SabrToothSqrl
    PA
    after 6 years, I regularly get home with < 20 miles to spare :p
    It's fiiiinnnnnneeeeeeeee
    • Funny x 2
  7. patnshan
    patnshan Member
    Milwaukee, WI USA
    There are at least two bad ones in Louisville right now. Plenty of others though, agreed. Does anyone know how to report bad superchargers?
  8. theothertom
    theothertom Member
    South Carolina
  9. Zcd1
    Zcd1 Member
    Chicago area
    Now that you've made that trip and come to that realization, next time just let the car tell you where and for how long to stop. As you've discovered, Supercharging is MUCH faster below about 60% SOC, so I try to arrive at each Supercharger <20% to make the trip as quick as it can be.
    If it's an overnight trip, hit a Supercharger before going to the hotel so you're ready for the next day.
  10. 2101Guy
    2101Guy Active Member
    i recently read where TEsla monitors and gets info via internet on broken chargers. I also read where its not good practice to hang the charging cord over the top of the charger, to indicate to other Tesla drivers an outage with that charger. Causes some sort of stress/damage on a certain part of the cord.
  11. 2101Guy
    on your trip back? I suggest using this service. Can even have it up and running in your browser on your MCU. Will ensure that your route is planned in the most efficient manner. Even more efficient than the tesla nav. A Better Routeplanner
    Also, as others have stated...optimum travel time is accomplished when keeping the battery between around 10% and about 70% or no more than 80%. More frequent stops, but much less time at each stop.
