I have recently had my driver's door weatherstrip replaced and the new one for some reason didn't seal the gap between the window and B-pillar. I could easily slide a piece of paper between the weatherstrip and the window glass. If you have the same problem here is an easy way to fix it.
If you remove the weatherstrip you can see that it is empty inside with two openings on the top and in the middle. So all you need to do is to stuff something squashy inside. I used a foam door weatherstrip from Lowes.
