I think you’re misinterpreting the FSD testing rules in California. The test driver has the responsibility to determine when it is necessary to take over. In a level 3 system the car tells the driver when to take over.
So it sounds like you agree Teslas system is not Level 3. And adding "in city" features won't change that.
So, just like I said, the testing rules in CA don't apply to Teslas FSD system as they plan to roll it out later this year.
It's really not. The text I quoted is pretty clear about this.
It's why EAP cars don't need permits, but Waymo does.
I still don't see the difference between "feature complete" FSD as a level 2 system and testing L3-5 FSD.
Uh...one is L3+ and the other isn't?
Again there's a fundamental, specific, difference between L2 and L3 in the SAE spec.
Teslas stated implementation of FSD as it rolls out is L2. Therefore it's
explicitly not required to do anything under CAs autonomous car rules since it's
explicitly not an autonomous vehicle.
To me that says that customers will be testing FSD.
In the same sense they're "testing" EAP/AP? Sure. Since both will have the exact same rules around them, and neither will require any regulatory approval.
In the sense they need permits in CA? Not at all, by the actual text of CAs rules.
Tesla clearly knows that they may run into regulatory problems with their plan in some jurisdictions.
In non-US countries quite possibly (see also how NoA came out in the US while it was delayed elsewhere... or summon in Canada on the Model 3 vs available in the US much earlier)- but not in the US with the L2 plan.
They expect there'll be problems- in the sense many states don't even
have regulations for this stuff yet- once they want to move to an L3 or higher system- hence why they're NOT promising to deliver one until that gets figured out... just an L2 version of FSD, which requires no approvals in the US.
