Garage Door Opening
Discussion in 'Model S' started by 7robert, Jan 30, 2016.
Tags:
  1. 7robert
    7robert New Member
    Washoe Valley, NV
    I received my S85D last December and have been enjoying it ever since. Last week, on several occasions last week I went out to my garage to find my Tesla setting there and the garage door open. I'm sure the door was closed after I parked the car. The only thing I can think of is the car opened the door for some reason. Has anyone else experienced this?
  2. bluetinc
    bluetinc Member
    MD
    Hi Robert,
    Have you checked the new settings on the homelink tab (in settings) to see if the open and close boxes are deselected?
    Peter
  3. jerry33
    Texas
    I haven't had this on mine, reset the homelink location.
  4. 7robert
    7robert New Member
    Washoe Valley, NV
    Hi Peter,
    Are you referring to: Settings>Driver Assistance and under the AutoPilot area at the top of the page there is a box "Use Auto HomeLink". Are you suggesting I should uncheck this box?
    Thanks,
    Bob
  5. BertL
    BertL Active Member
    Carlsbad, CA
    If you have an older opener without rolling codes, the problem could also be your neighbors using their opener, which also opens yours. Others threads discuss some of those odd situations. I had to change the dip switches manually in my Moms (very) old door opener and it's remote since the new neighbor down the street had this thing about pressing their button closer to my moms house -- just enough apparently to open her door with theirs every time.
    ...my point being, it could be your Tesla and Homelink especially after this 7.1 update that I've found opening the wrong door in a specific scenario, but you may want to ensure you've ruled out other things that don't involve your Tesla as well. Good luck.
  6. sorka
    sorka Well-Known Member
    Merced, CA
    Could you have triggered summons on your fob by lying or sitting on it or something?
  7. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    Are you saying that your Tesla Homelink can work with rolling codes?
    My new Sommer Direct Drive opener's rolling code remote can't be paired with Tesla Homelink because, according to Sommer, Tesla is not willing to modify their software to be compatible. I had to buy a non-rolling code receiver in order to use Homelink. Our Lexus learned the rolling code in 30 seconds.
  8. BertL
    BertL Active Member
    Carlsbad, CA
    Yes, my MS Homelink works perfectly with my LiftMaster garage door opener that has rolling codes, as did my previous two Lexus, MBZ and BMW.
  9. clyjr
    clyjr Member
    Charlotte, NC
    Are you 100% sure it was closed all the way? My last house I had an issue with the close pressure being too sensitive and the door would close all of the way, pause, then reverse and re-open. Only way I noticed was the alarm company calling telling me my garage door alarm went off when I was a couple miles away...
