If you think EVs are not good for cold weather, it is actually worse for gas cars:
Water crystallization in fuel.
Engine block cracking due to improper antifreeze.
Oil pump failure due to extreme viscosity change.
Higher fuel consumption by not reaching the Hydrothermomechanical efficiency point.
Permanent damage to head gasket due to high point heat and cold cycle between the block and the head.
You see, at least your EV can keep on going, it's just goes less. Your gas car could fail all together.
