After several delays (not Tesla's fault FWIW), our PV install and wiring was finally completed today. Yay!
Tesla solar only. No Powerwalls at present (though considering them more and more!).
The crew that completed the installation were used to new construction and didn't have a lot of "consumer" knowledge as far as the gateway and the Tesla app and making sure all of that was setup.
Here's what they did:
1) The installer showed me his phone running a SolarEdge app. It showed the panels were active. Cloudy day - so not much.
2) He gave me a box with a SolarCity gateway. I have the "Neo Gateway" shown here:
Troubleshooting Your Gateway | Tesla Support
3) He told me to "download the app". I asked him which app and he said he used "SolarEdge". I asked if the Tesla app should work for basic monitoring and he said "Yes". But honestly, he didn't seem to have much experience with the Tesla app.
I hooked up the gateway. "No signal" illuminated on the front. Installers had already left at this point. I got a really long network cable and moved it within a few feet (and a single wall) from the equipment they set up since I noticed the gateway mentioned ZigBee (so I assumed it might need to be closer).
Unfortunately, even having the gateway within ~7 feet of the outside equipment/inverter, still it said "no signal".
I called Tesla. They told me that everything was functioning "as expected" and that the gateway wouldn't connect to the inverter until it was activated as part of the interconnection/utility process. Is this accurate?
In the Tesla app, when I swipe over to where the Tesla energy section should be, I only see the "advertisement" / animation screen with the contact us for quote information. So basically as if I didn't have solar.
Questions from a Tesla Solar noob:
1) Is it accurate that the gateway will always say "No signal" until the whole system is completely active (which they tell me will be likely "weeks")? Or might I actually have a defective gateway? Or a misconfigured one?
2) Besides cosmetically, are there any known differences between the "Neo Gateway" and the "X2e Gateway"? Is one newer than the other or do they still actively use both?
3) The installer mentioned the "SolarEdge" app. I found it in the app store and downloaded it but have no idea about WHICH account it wants for login. I assume it is not the Tesla account? Where does one get an account for this app? There is no "sign up" option on the mobile app that I can see.
Thanks in advance
Thanks in advance
