"If it were real degradation it could not have recovered - therefore it isn't degradation at all and those flawed stats apps need to stop labelling it at such."
This^^^^^^^^^^^
If the battery truly degraded, then how does that number rise. Do you believe in battery ressurection?
The degradation crowd is absurd. I ask them OVER and OVER again to state how many real miles they get on a charge and they never answer the question. They constantly hide behind third party apps that have convinced them they're getting screwed.
There are multiple 'degradation' types, some a permanent, some are recoverable. (Same as an ICE car)
By 'degradation' I am referring to the car reporting less mileage available than it did in the past. I am referring to 'Available Range Degradation', rather than 'Battery Degradation'.
In a similar way to an ICE car referring to the MPG getting worse, you get less miles out of a tank of gas than before. All kinds of reasons that may cause that, but at the end of the day, if you are getting 15% fewer miles before the gauge reads empty, you are getting 15% fewer miles. (It might be that the gauge is not reading accurate any more, there's a hole in the tank, or the engine needs tuning...)
Examples:
1) Permanent physical/chemical battery degradation.
2) Unbalanced packs/blocks/cell. Which can be re balanced
3) BMS estimation in-accuracy.
Can't do much about #1 (apart from following the charging guidelines long term, to some extent) The initial degradation I believe is mainly just down to chemistry/luck.
But #2, #3 and others can be effected by behavior. Looking from the outside, it's not possible to distinguish the cause of the 'degradation', just that the car is reporting less available range
My answer:
When I got the car driving at approx 80% average efficiency with a reported range of 307 miles, which is realistic driving in a P3D, I would get 250 miles till it indicated I would need to fill up.
After approx 12 months, the reported range was down to 272 miles, and at that same 80% efficiency, I would get 215 miles til it indicated I would need to fill up.
That's a significant difference, whereby on some days, for the same trip, I would need to a quick splash/dash near the end of the trip.
I could drive also drive at 100% efficiency (i.e. at rated energy usage), which would squeeze out a few more miles.
However, Now, after changing charging habits and not commuting, for several months, the reported range is back up to 296 miles. So I can guess that the loss of range wasn't largely due to #1, it was due to #2, #3, something else, and probably a combination of all three. The 'Range Degradation' has reversed itself to a large degree, but the 'Physical Battery Degradation' almost certainly hasn't.
But #1 being less significant, and is what Tesla measures when they are measuring 'Physical Battery Degradation'. (vs Reported Range Degradation)
Now Knowing what affects each of the factors, enables, if you want, to modify your behavior to gain more value out of the car. You do it in an ICE car, why not in an Electric. Different factors
No, I have never tries to run the car down to 0(-ve) miles or percentage to see if the missing miles were just there hiding, that's not realistic. If the car is telling me I have 250miles available, I have 250miles available. Doesn't matter what the cause is, still can't drive more than 250miles.
As far as labeling goes, 'Battery Degradation Report' may not be 100% accurate (in Tesla FI), it's really measuring a whole 'system' not just the physical batteries. I'm not interesting in the 'physical batteries' themselves anyhow, I am interested in the 'Battery System', and how that Battery System is affecting the 'value' of my car to me.
Not obsessing about every little change, but being able to see/track a trend is useful/valuable information.
