I rented a garage which has a 120v outlet. It worked fine with the UMC the first time that I tried it, but the second and the forth times tripped the GFCI outlet.
This is fine, as it works after resetting and only happened when plugging in (so far), but the garage door opener is daisy chained off that outlet and trips with it. So if, by chance it tripped with the door closed I'd be locked out.
I'm familiar with the gfci breaker threads here - advice is to replace them, but how are they broken? The UMC tests the ground, the outlet should trip.
Reason I'm asking is that if the outlet is broken I can ask for it to be fixed, but if it is working as-designed then it is a more complicated request.
