What are we attempting to glean from this experiment? Dynos are good for measurement of relative change, but not good for absolute measurements. Moreover, testing on different days, at different temperatures, on different dynamometers, etc. all result in different numbers. So two of the exact same car at the exact same SoC can get different results just by being on different rigs.
If someone wants to pay $100 for dyno time, that's fine and fun. But it isn't really going to give us anything useful unless we're measuring something against it.
Yes that's RWD. Which the whole point of the thread is that there aren't good AWD dynos out yet!
Totally agree! The exact same car measured in different type of dyno can show vastly different horsepower and torque numbers.You missed the point of my pose completely. A dyno pull isn't a reliable or meaningful number in absolute terms. It is a tool best used relatively when measuring power improvements on the same vehicle, on the same dynamometer, with upgraded parts. In other words, our two exact same cars on different rollers will have different numbers, which means the measurement is of no use to compare our two exact same cars. This is extremely widely known in the tuning industry and covered at great length on tuner forums.
I found this one that is specific to the non-performance model, in case you really want to see the dyno numbers that isn't quite real world
Since you get 3 runs for $100, I would suggest to try to start the 1st run with as close to full charge as possible, because I am very curious what the max/peak hp for the AWD. When you do the second run, the battery charge will be lower and the 3rd run will be even lower. This will also give us info on what the hp is like as the battery charge becomes lower.
I’m happy to reschedule the date to one that works for both of us. Feel free to message me.
Northside of Richmond near I 95 and 64. National Speed. 4022 Glenside Dr, Richmond, VA 23228
I would just advice the people who really want to know what kind of performance they are getting relative to competition such as BMW M3, Mercedes C class AMG etc. They really should just look at 1/4 drag time in terms of seconds and trap speed in mph. It is a much much better measure of real world performance comparison between vehicles. 1/4 mile performance takes account into the weight of the vehicle, traction, transmission efficiency and performance etc, while doing dyno is just about the performance of the engine/motor and nothing else. 1/4 mile is very much as real world as you can get.
I know you are looking for non-performance model 3 numbers. But just as an example, here is the comparison of Model 3 performance vs BMW m3.
as you can see, Model 3 Performance has faster trap speed as well as faster time in 1/8 mile race and 1/4 mile in all 3 races. Consistently better and faster than BMW m3 across the board.
I understand that different Dynos will have slightly different results, in the same way that track results will vary based on wind, tire wear, temp, track conditions, etc.
What is the standard deviation on dyno results.
Are we talking under 10% tolerance?
I don’t think anyone here cares if it might vary 10-30HP
... most are just looking for some kind of quantified ballpark.
If they really had a variation of 100hp it would render the machines completely pointless and they would not exist. Perhaps you had a poor experience or someone that didn’t know what they were doing.
I appreciate your concerns but still exctied and interested in seeing the results.
In fairness, he is alluding to an accuracy vs precision issue. If two machines are wildly innacurate (as he is suggesting) but precise, yielding repeatable results, they can still be useful as a tool for comparing relative values. I.e. did this exhaust swap add HP or sacrifice torque? Assuming both runs are done on the same machine under the same conditions, it doesn’t matter that the values are off dramatically as compared to what another machine would report.
I am, however, suspicious of the reported 100hp discrepancy between machines. If true, that sounds like one of the shops is doing something wrong, whether it be in the machine’s calibration or the test setup. Of course, dynos are not usually run by scientists, and are primarily used for relative comparisons, so ::shrug::
I still want to see the results!
...I'd argue though that even from an accuracy standpoint the variation between different machines shouldn't be that large.
I did some quick searching and the best quantified examples I found were maybe 10-20 HP differences between dyna machines.
It also appears that some of the variations between machines may be minimized by the fact these are EV's. Altitude, gas quality, air intake, and other factors that might create "some" variation in accuracy between machines will likely be further minimized. Yes, things like how well was the vehicle strapped down could still have impacts, but likely negligible, certainly for this exercise.
What do auto manufacturers that publish their HP and Torque specs utilize for testing?
