Also, if you enter in a destination for guidance, it will re-center your arrow. After you cancel the destination, it still continues with the arrow centered
The mode button at the top cycles through a few settings. The vehicle location is tracked when the button is blue. As soon as you touch it (the map) wrong, tracking stops. Glance at the button before reaching for a reset.
On the 2022 Y, the answer is to touch the location tear-drop icon which is located in the short list under the "N" on the nav map. It'll be gray if you pinch or move the map with your fingers in any way..... Touching the tear-drop 'ungrays" the icon.
