Presently my soul grew stronger; hesitating then no longer,
“Sir,” said I, “or Madam, truly your forgiveness I implore;
But the fact is I was napping, and so gently you came rapping,
And so faintly you came tapping, tapping at my chamber door,
That I scarce was sure I heard you”—here I opened wide the door;—
Darkness there and nothing more.
My wheel wells had been vexing me for some time. It took a while to figure out where the noise was coming from. I thought A-pillar, then dash behind the steering wheel. One of the difficulties with finding the noise is that to start with it was only happening at high speeds (50mph and up), only later could I reproduce at lower speeds. This is unusual for a rattle. It took a Ranger to track it down, clever fellow. My liner is NOT fastened to the back of wheel well. The hole in the liner is there but the bolt welded to the well isn't there, just a flat spot where it would be.
The Ranger couldn't find anything in his database so he did a hack fix with a zip tie, which indeed stopped the noise. Two issues though, one is that I then later noticed the noise happening in the passenger wheel well, too. But the bigger issue is that within about 1000-1500 miles the tie wrap wore and broke, with the tapping returning.
Enter Clever Ranger #2, who I'm pretty sure has this one licked now (pending Tesla HQ issuing a new liner design). He wrapped felt backed tape (from a roughly 4" wide roll of it) on the backside of the liner, towards the fender edge in two places. Towards the door and then at the top of the wheel well. Here's a picture of where it went toward the door (pardon the dirt, I drove through some mud):
The felt is dark black, so it's the very dark strip next to the outside of the liner. It's mostly on the backside but it's wrapped around the edge of the liner to keep the edge of the liner form tapping to. It tappers out towards that hole near the bottom of the liner, and the wrap around extends up past the top of the photo. In total about 8-9" of tape was applied here.
On the top it was about 6" at the very top of the well arch. On the top he applied it the the metal of the wheel well, rather than the liner itself as was done at the backside towards the door.
I'd like to thank wrap it up with a shout out to the two Rangers that helped me out here and came up with the solution.
