The cheap construction generators are REALLY noisy, cantankerous, and generally a PITA.
Generac whole house consumer generators have a long history of failing soon, especially by burning up all their oil then self destructing. During "Hurricane" Sandy in NJ at least 8 of my mother's neighbors had Generacs that failed.
I've had good luck with Kohlers. One was from 1946, the most recent was installed about 3 years ago.
Depending on how much you expect to use the generator, propane is a good fuel. It lasts forever and doesn't degrade like gasoline. Note that a full house generator will need something MUCH larger than a BBQ tank, or even a 100 lb tank. Natural gas should be good, but look what happened this winter in Texas.
My preference has been for diesel since you can fefuel from a jerry can, but consumer diesel generators seem nearly extinct. Kubota makes excellent small-medium diesels and make a (expensive) generator that looks excellent. Should be very good. I've had half a dozen Kubotas tractors (some for 20+ years), and all were extremely reliable. None died, and only one has been retired (Friend took it and restored it).
I have used several diesel Kohlers for off grid use over the decades. My present emergency generator is a propane Kohler.
If you want gasoline and portable, Hondas are the best. Fairly quiet, very reliable. Have had about half a dozen over the years for various properties. Make sure you get an actual Honda generator, not a Honda engine attached to a crappy generator.
