Charging with a gas generator?
Bigjohn892
53
25
Chattanooga TN
I have ordered the truck but have a question . We will be camping with the truck for extended periods and wonder if you can charge the truck with a standard gas generator (220VAC)? The sine wave output isn't nearly as clean as house current. Will Tesla's electronics allow this?
Anyone try this with their Tesla?
Chisale
210
180
Ohio
The owner's manuals tell you not to do it but it is possible. It would be extremely wasteful and I personally wouldn't count on it unless in a real bind.
Jrzapata
144
176
Texas
There’s something I saw in some videos about having to modify the generators to be “stable enough” for the car not to blow it. It is extremely inefficient in the mileage per gallon you would get
brucet999
2,671
1,482
Huntington Beach, CA
How practical would that be? 5 gallons of gasoline x 30% efficiency of motor x 90% efficiency of generator x 87% efficiency of on board charger = 1.175 equivalent gallons = 43 kWh. Much better than I had supposed it would be.
Reactions: ebmcs03
mswlogo
5,965
4,572
MA, NH
Sure. But you’d need one heck a large generator running potentially for a long time. Watch out for ones with “floating neutral”, might not like that. You might consider a propane one. They run longer, cleaner and quieter. But you may need a permit to carry enough. Note also runtime on generators are typically rated for partial load, like 25%. My 3000 watt, 100lb generator runs 18hr’s at 25%. That’s about 7 miles / hr in a Model 3. Probaby half that for a Cyberctruck. So 4 hr’s all out would get you 5 miles range. so maybe a generator twice the size could add 200 miles in 24 hr’s full out. I think it would take 200lbs of propane.
Mach Schnell!
P100D Pilot & future Tri-Motor CyberTruck Driver
Oct 27, 2016
105
76
San Francisco Bay Area
Yesterday I used my Tesla as a variable test load for a new 8kW (propane) generator.
Sealander
31
20
Houston North
Not a problem charging my Model 3 with a 5kw diesel generator and I figured out my mileage with the diesel consumption of the generator to be about 25 MPG. Better than my previous ICE car!
Reactions: Msjulie
mswlogo
5,965
4,572
MA, NH
Yesterday I used my Tesla as a variable test load for a new 8kW (propane) generator. View attachment 480959View attachment 480960
Is that an inverting generator? Bet ya it goes through a 20lb tank every 2 hrs at full load. So you are talking 5 20lb tanks for a serious charge session (on a Model S). The Cybertruck will likely be less efficient (depending on trim). Notice they hid the wh/mi in all the rides. Probably cruising at 500 wh/mi.
EDIT: 5.0hrs 50% load for 8000watt Champion generator. So 2.5hrs at full load. I was close.
JBee
160
115
WA
Doing a reverse calculation from the solar option EM mentioned, given we know the car areas for PV, CT should be using around 330Wh/mile. Don't ask me how.
What you need is a DC generator to increase the efficiency, like the Polar ones, and get one that either fits in the frunk or under the bed. 30% efficiency is a bit high for a small motor though, lets call it 25% or around 350ml/kWh. So about 11kWh a gallon. Worth it IMHO. Need an internal connector somewhere.
Mach Schnell!
Oct 27, 2016
105
76
Close to the published rating. I do have a few 40 pound tanks. I didn’t buy it to charge my Tesla, haha. With our frequent PG&E power shutdowns whenever it gets windy in CA is why. The Tesla is just a convenient programmable load test fixture.
Reactions: mswlogo
Uncle Paul
6,105
6,607
Canyon Lake,CA
Idea of using a gas generator to charge Tesla is against their prime objective.
It has been reported that the Truck will have an optional Solar Roof, with 15-20 miles added per day.
Be better off bringing along additional solar panels than a generator and fuel.
mswlogo
5,965
4,572
MA, NH
Understood.
Just letting OP know how much "stuff" he'd have to carry camping to charge his Tesla, once.
I'm sure that 8000W generator is no lightweight either.
The 20Lb tanks are like 4 gallons at around $3.00 a gallon. Probably ~70 lbs to fill Model S with 200 miles. ~$40.00.
Not bad considering how crazy inefficient it is.
Reactions: Mach Schnell!
JBee
160
115
WA
Solar panels only work if the sun is shining for enough of the day, and you are stationary long enough to use them. In winter they barely work at all on a overcast day.
There is nothing inherently "wrong" with using a biofuel source for power provided it's a sustainable one. Tesla objectives, or directives are not law, and once purchased the vehicle can be used as the customer wishes without Telas approval. The worst they can do is not cover it under warranty.
Technically there is no difference to the power coming out of the socket, provided you have a half decent generator, and they would never know. Another way to do it is use a range extending trailer, that is powered by a ICE, or for that matter get a tow from any ICE car with the CT in regen. Has been proven to work, and is not even that bad efficiency wise. (once again Tesla won't be able to tell that from braking or going down a hill)
Kevy Baby
Dis-Member
Aug 11, 2019
1,752
1,705
Brea, CA
I don't care why Tesla's objectives are; if I am out in a remote area, I'm gonna do what I need to make sure I get back. If that is a gas genny, so be it.
