Where did you find the firmware update for the dsp, can you share
Can you take the picture showing which post you grounded? I see on the Hansshow picture there are two posts next to the power.
Also how did you connect the harness to the new rear speakers? How did you install the new rear speakers in place of the OEM? Thanks
Any chance you have the link for the software for those instructions? The one I found is different than what you attached. audio upgrade system - Google DriveDSP instructions from Hansshow attached
I grounded to the post right next to the power terminal. The kit did activate the rear stock speakers. I did find that I was able to also plug in the new speakers and have them work, but I haven't figured out where, or if I would install these. The point of buying this kit was to do this with as little intrusion to the main car's structure.
Ah, I see the video was updated yesterday while I was working on my car! Found the link here: Hansshow/Model-3-Audio-Verision-E-DSP-softwareLinked in the video description above. Some GitHub link?
So you mean we can have the stock rear and the Hansshow rear speakers installed all at the same time?Channel 7 and 8 activates the new rear speakers so in theory if you wanted to add more speakers you technically could
That was what I experienced myself, yes. I did not install the news ones though. I may run the wires though into the back in the event I decide to later add those in.So you mean we can have the stock rear and the Hansshow rear speakers installed all at the same time?
These Hansshow rear speakers are assigned as channel 5 and 6?
The harness has the plugs labelled as "OEM rear surround speaker plug A and B", do you use them to connect to the existing stock rear speakers?
Anyone have suggestions as to what to set the gain,lfe,and bass boost to on the amp? Once the amp is in you won't be able to access very easy.
Were you able to put the DSP underneath the central console or under the front passenger seat?I grounded to the post right next to the power terminal. The kit did activate the rear stock speakers. I did find that I was able to also plug in the new speakers and have them work, but I haven't figured out where, or if I would install these. The point of buying this kit was to do this with as little intrusion to the main car's structure.
But then can you slide it u der the passenger seat?Cable is only long enough for under the passenger seat. Can't make it into the glove box or the center console.
