In preparation for a trip I dug out my old 12V tire pump, bought some new plugs and reamer tools ready to make a repair kit in case it would be needed.
The pump had been sitting for a while so I did a test. I let the front tire down to 20psi, plugged in the pump and started to fill it. All went good for 2-3 minutes then the pump stopped. Searching the for the cause of the stoppage it was the cigarette outlet had no power. Then I found out there are no fuses in this car, you have to wait 1-2 hours for it to reset itself. This is not acceptable for a road repair.
The outlet is rated at 12 amps, checking the pump it draws 10.5 - 11.0 read with a meter. I thought I would just buy a new pump, maybe they are more efficient but all the specs i read were 10 amps and up.
So my question is what are you (that have a pump) using, and have you actually filled a tire or is the first time going to be on an abandoned road with a lighter socket failure?
