Yep, definitely a case of way too much toe in. You might be able to squeeze a bit more life out of the two tires, but you definitely need an alignment.More wear than the rear tires, but not as bad as passenger side. Driver side is first photo.
View attachment 626799View attachment 626800
the minimalistic approach is extended into the tesla’s dealership! they have nothing other than a show room!
you will be dreaming if you think they have an alignment machine in their back to prep the alignment of your new car!
Yes, given the dozen or so mechanical, electrical, and assembly issues I have already had, Vegas would say smart money is that it was bad off the assembly line. Tesla had already sent me an estimate for about $700 to replace and balance the tires.
Maybe not all but my service centre does. They change tires, balance them and can do wheel alignments. I brought mine in as I thought the steering to be acting odd. Car was driven, checked, and alignment verified. Turns out the performance tires with the 20" wheels are very sensitive to small ruts in the road as when I put on 19" snow tires the issue is no more.
That's not too bad in my opinion. How many miles and have they been rotated?We have the same problem with both front tires. We have an appointment with the Service Center. I am not happy about this...
Front left at 4800 miles (rears are normal):
Tesla isn't the only manufacturer with alignment issues from the factory. Part of "dealer prep" has been to check alignment on all cars, which I know is done at the 4 Toyota dealerships I've dealt with. Ditto for VW.
Venturer: Question about driving style. Model Y is heavy, possibly heavier than your previous car. If you are consistently turning, while braking, at...uhh...well...assertive/aggressive speeds (because the Y can do it, and it's FUN!), you'll wear your tires out very quickly.
...just a thought...
btw - why is it that the left front was misaligned, but the right front had the excessive wear?
