I’d like to stuff something under the rear passenger seats to muffle to 4-6khz sound emitting from the electronics. Service center said noise is normal and penthouse seal is aligned properly (which it visually appears to be). The noise is most noticeable driving without music or music at low volume greater than 30mph.
I’ve ordered some mass loaded polyurethane to put in there but I want something there to absorb the sound as the MLV will only be reflecting it away.
What flexible, semi-heat resistant options are there? I looked at mineral wool to go under the MLV but I’m concerned if you drove with the windows open and air flows through there that it will spit fiberglass all around the car—bad news bears if that were to happen.
There are mats under the floor carpet of some cars (looks like wool/cotton mix—often gray in color) that would possibly work and are flexible which is key. I found something similar to this on Soundproof cow but for a $30 sheet they wanted $150+ In shipping.
Any other ideas or recommendations? Thanks I’m advance!
