vitesse
I think I may have identified the reason for the unreliable home charging via my ROLEC. It may not be the ROLEC at all, but the house's main fuse not rated high enough. The installers failed to notify me that the main fuse needed to be beefed up from 60A to 100A.
This is done for free by UK Power Networks, but when I contacted them about this they said they would only do the fuse upgrade if it could be verified that the meter and consumer unit 'tails' were up to spec. (25mm).
I wish all this had been explained to me much earlier! I hope this post will help others in the future.
I might need an electrician to check the 'local' side of the wiring while my electricity supplier will need to look at the supply side, I believe.
To complicate matters further, I want to switch suppliers and that will require my current smart meter to be replaced by a different one. So maybe I should kill two birds with one stone? The only problem is that this could take quite a few weeks In the mean time if I use the ROLEC I risk blowing the main fuse to the house! So until this is resolved I will be using the UMC and charging at 10A (6 miles range per hour).
