rush6410
In normal working operation, the auto open feature is specifically location based regardless of Drive or Reverse engagement. Mine has always worked for the past year through dozens of updates. I am currently on .44; latest available to me. The behavior is as you approach the location that was programmed, 1) The Homelink drops from top of display. 2) You see distance count down. 3) When hits 0, signal to open is sent. I have an audible sound turn on when command is sent. This occurs whether I am in D or R. As I leave the location, command is sent as I get specified distance away. If at anytime I override the command, it will not send open or close until I leave the location and re-approach. So, it is specifically location based. Be sure to set location exactly where you want the 0 position to be sent. If the location is off, the commands will not be sent as expected. To Reset location:Now that it works, I've noticed that the auto-open feature only works when the car is in drive. I have a long driveway with limited turn-around space and a rear facing garage, so I always back up the driveway. around the corner, and then front into the garage. The door auto-opens when I shift into drive.
Resetting the Location of the
HomeLink Device
If you experience situations in which you
sometimes drive up to your HomeLink Device
and it doesn't open, or the HomeLink icon on
the touchscreen's status bar does not display
the dropdown when you approach the device,
you may need to reset the device's location.
To do so, park as close as possible to the
HomeLink device (garage door, gate, etc.) and
display the HomeLink settings page by
touching Controls > Settings > HomeLink.
Choose the name of the programmed device,
and touch Reset Location.
With all that said, normal working operation would assume your firmware is operating as expected. If it works on any model with the same hardware specs you have, you should assume the sent firmware from Tesla is good. That doesn't necessarily mean you vehicle received properly. I would assume there is some kind of check sum error report that is run at time of loading similar to firmware update on your PC. I would assume if it didn't work, you vehicle would present an error on load. If you can open and close manually from the display, but the approach and leave location is not working, try reseting location. If it still doesn't work, call support. They can pull logs and troubleshoot. It would work if the conditions I mention above work.
