Racerx22b
@unplggdd on Instagram
Just got back from a Disney trip and wanted to advise everyone that if you opt to stay in the Cabins at the Fort Wilderness Lodge you have access to a 5/20 outlet right in your parking space. See attached pics. I was able to get 117v/16A/5mph charge during my stay. My outlet was a little "wonky" so my 5/20 adapter hung out just a bit but never affected charging. I would suggest bringing an array of bungee cords so you could take the weight off the plug. You could connect the bungee to the window directly above the outlet. If you're really serious about using the bungee bring a cordless drill and long wood screw and just make your own place to connect your bungee hook. Trust me, nobody would be the wiser.
I've also read that Disney will allow you to charge in a vacant campsite at a 14/50 outlet assuming one is available as long as you are staying in a cabin. i wasn't able to verify this during my stay as I was able to fully recharge over 2 days.
EDIT: Forgot to mention, if you are in possession of a 25" 14/50 extension cord you could feasibly pull out the slide in range and run the cord from the oven outlet, out the window, and then connect your UMC to it and charge at 40amps.
Cabins at Disney's Fort Wilderness Lodge
4510 N Fort Wilderness Trail Orlando, Florida 32830
