This is true if
Creep mode is not activated.
Note: This is something that I find to a little bit scary while I was parked closely between two cars in parallel park in a slanted street.
In this situation, I needed to backup to
move up the hill:
- So I put my feet on the brake, engage the level from
Park to
Reverse
- Then I removed my feet from the brake pedal and t
he car started to move downward because I didn't immediately accelerate,
or I might have
not press enough on the accelerator because I was very close to the car behind me and didn't want to ram into.
In this kind of situation, I set now the Creep mode which allow to keep the car still even if you don't accelerate,
something similar to driving a car with an automatic transmission.
More on this subject if you are interested:
Will creep keep car from rolling backward on steep hills?
Note: Otherwise I never use Creep mode, especially since I never had an automatic car and only had a manual transmission car.
Not having an emergency brake is certainly something challenging when you are used to.
