How do you release the charge port using the app?
Discussion in 'Australia & New Zealand' started by MMinehan, Sep 25, 2016.
  1. MMinehan
    MMinehan Member
    Auckland, New Zealand
    So I am struggling to work out how you remotely release the charge port using the app while the car is charging.
    The setting is like this: you are charging at a public charger and have left an EV etiquette tag saying it is OK to unplug. The tag has your phone number on it so people can call you. Like this:
    Then I get a call asking how do they unplug the charger. So I go to the app an nowhere can I find a way to release the plug. I can stop the charging but that still does not release the plug. Even when fully charged I can't see a way to release the plug using the app. Here's some screen shots from my app:
    I have searched the web and yes you can open the port door using the app. But how do you release the plug?
    Even using the button the plug does not release the plug while the car is locked.
    Do I have to unlock the entire car in order for the plug to be released? If you can't remotely release the plug it's not going to be very nice for other people who may want to use the charger from an adjacent parking space.
    Any ideas? Am I missing something obvious?
    Marty
  2. bredi
    bredi Member
    San Francisco
    i learned that if you unlock the car, or have the trunk open, you can hold down the charger button and it will release.
    on the key fob, holding down the trunk button also opens and releases the plug.
    ( i i didn't read the whold thread, so apologies if this was stated.).
  3. MMinehan
    MMinehan Member
    I should have made myself a bit clearer. I want to be able to release the plug while not actually being there, using the app. If I am at work for example and am using the public charger down the road I want to be able to release the plug for other users without having to go there myself. I would prefer not to have to unlock the entire car. Otherwise there is no point in using the EV etiquette tags.
  4. bredi
    bredi Member
    San Francisco
    I wish all ev owners thought like you!
    i had the thought too, its an app request.
  5. FlatSix911
    FlatSix911 918 Hybrid
    Silicon Valley
    Try using the remote app to unlock your car ... then re-lock :cool:
  6. MDK
    MDK Aussie Member
    Western Down Under
    I just tested this at home (with keyfob out of range of the car)
    With the car plugged in to a powered cable it only gives the option of "start charge" or "stop charge"
    If I switch off power to my wall connector I get the option to "Unlock Port"
    and I've confirmed this a) allows the cable to be removed and b) keeps the car locked.
    However this appears to be a limitation with the Tesla App, not the API, because the command to open the chargeport door can also be used to unlock the cable if one is plugged in
    See Tesla Model S JSON API · Apiary
    I verified this with "teslacmd -P" from the teslams tools - I was able to use that to unlock the cable without unlocking the car, while my HPWC was powered.
    That means it's possible for a third-party app to give you the function you want - which is more likely than Tesla fixing this "feature" in the official app.
  7. MMinehan
    MMinehan Member
    Thanks for the investigative work MDK.
    So in order for me to release the cable remotely using the app I have to get the person to power down the charger first. Or find a 3rd part Android app with that function. What a pain. I gather asking Tesla to add this to their app is unlikely to result in the desired outcome.
    Do you know of any such apps?
  8. Rawbznz
    Rawbznz Member
    1 AU
    There's one called Remote S which seems to have more options than the tesla app. My tesla arrives this week so I haven't tried it yet.
    Remote S does seem to have an open port option.
  9. MMinehan
    MMinehan Member
    Unfortunately I am an Android user. This seems to be iOS. Unless I am looking in the wrong places.
  10. brewster
    brewster Member
    Portland. Vic. Australia
    Just confirmed Port Unlock worked with RemoteS. Yes only iOS
  11. Mark E
    Mark E Member
    Sydney NSW
    The standard Tesla IOS app can unlock the charge port when connected to a HPWC, so maybe request this as a fix for the Android version. I just checked it on my phone to be sure that it's there on IOS and it is.
  12. MMinehan
    MMinehan Member
    Any idea how to contact Tesla re app suggestions? Most of the links I have found re-direct to Tesla AU service.
  13. Vegas
    Vegas Member
    Brisbane, Australia
    Perhaps posting your suggestion on the US TMC site would get a response from people that have encountered this before and come up with solution?
  14. MMinehan
    MMinehan Member
