An alignment rack cannot be
accurate to .005 degrees. At best it's maybe accurate to .2 degrees if it's perfectly calibrated and expertly used.
And at best it's maybe
repeatable to .1 degree, this is not the same as accuracy.
It can be
precise to whatever number of decimal places the marketing department wants. This has nothing to do with accuracy or repeatability, it's just marketing. But note that
precision must always be higher than accuracy so it would have to read angles of .0005 degrees in order to be usefully accurate to .005 degrees.
FYI, a layer of conventional automotive wax on the rim of an 18" wheel would change the measurement by 0.005 degrees if modern Hunters still used static rim references. Driving a 1/4 turn with the swinging targets compensates for wheel surface imperfections but the car's suspension can easily wiggle more than .1 degree just from rolling a little on the rack.
Note that Hunter's "acceptable range" for the rack's calibration accuracy is +/-0.1 deg:
And on top of that, each wheel target has its own errors and calibration:
And if you did all the math to see what the maximum cumulative error could be between a barely in-spec frame and 4 barely in-spec targets you'd see what I mean. Then add in the fact that these calibrations aren't accurate either - there's all the unknown inaccuracies of the targets and sensors that aren't even being considered here because you're using those very same targets/sensors to perform the calibration.
