How fast should my 'new' 90D be?
Discussion in 'Model S' started by kutkuzak, Oct 1, 2017.
Tags:
  1. kutkuzak
    kutkuzak Patrick
    Indiana
    I've got a new 90D (got good deal on service loaner) that I've had for about a month that was built I believe in May of this year.
    What should I expect the 0-60 to be? I seem to pretty consistently get 4.5sec 0-60 but never better.
    Considering the car was supposedly 'new' when I got it, to have 75D's rated at 4.2sec for some time now, this stings a little.
    Am I just getting a bad launch or am I really limited to 4.5, even with the bigger battery (which used to have faster times) ?
    Thanks!
    Patrick
  2. vthomas
    vthomas Member
    I just did my first Powertools 0-60 run today with my 90D that was new off the line about 3 wks ago. I ran a slight uphill, slight curved section and got 4.0 sec flat. Peaked at 450 hp on that run, but I’ve seen it as high as 480 hp.
  3. zackmilo
    zackmilo Matching X+3
    Los Angeles, CA
    Just saw my X90D at 486HP in PowerTools. That wasn’t even full throttle. You should be getting 4 seconds flat. What wheels do you have?
  4. kutkuzak
    kutkuzak Patrick
    Indiana
    19" slipstream - it has goodyears on it (not sure which off the top of my head).
  5. RYCO
    RYCO Member
    Gilbert AZ
    What is power tools?
  6. dragoljub
    dragoljub Member
    Los Altos, CA
    Yes what is it? I too would like to try this out with my 90D delivered Feb 2017
  7. calisnow
    calisnow Active Member
    Los Angeles
    How do you know you are doing 0-60 in 4.5 and why do you think this measured time is accurate enough to compare to a manufacturer published spec time of a different model? If you've run multiple acceleration runs with the same measuring device in a new 75D and you're seeing 4.2 then you have a valid basis of comparison - 'til then this is conjecture.
  8. No2DinosaurFuel
    No2DinosaurFuel Active Member
    San Diego, California
    Charge to 90% or higher. Make sure your battery is sufficiently warm. Typically you do this by going to a supercharging station or do repeated launches. Or drive aggressively. I.e. accelerate hard and regen hard. Also make sure you are not carrying around excess weight.
    You should get the rated acceleration.
    Under cold or low capacity state your acceleration can be slower than rated.
  9. vthomas
    vthomas Member
    It’s an app that ties to your car. You can find it for iOS. There’s some version or similar for Android, but I don’t know offhand.
  10. kutkuzak
    kutkuzak Patrick
    Indiana
    I’m using PowerTools and comparing to a friend and his new 75d who gets 4.2 (and from what tesla states as the specs for the current 75d’s). There’s no conjecture about it.
  11. kutkuzak
    kutkuzak Patrick
    Indiana
    That’s one thing I haven’t done. I just charge to 70%. It’s odd that I get 4.5 so consistently though. I could swear that used to be one of the ‘old’ rated speeds for the model but that’s why I’m asking here.
    I take it that 90d’s haven’t changed in a while and I should definitely get 4 flat?
  12. csanders90D
    csanders90D Supporting Member
    San Diego, CA
    Power tools only gets a reading every 0.25 second. There's no guarantee that your 0-60 run will start right at one of its readings, so you're losing up to 0.25 seconds at the start. Similarly, at the end, you can be at or above 60 for up to 0.25 seconds before it's recorded. So PowerTools is adding anywhere from 0 to 0.5 seconds to your run. For an accurate 0-60, you need a more precise tool.
    One method I've used is to video record the instrument cluster as you do the run. Then you can step frame by frame and get an answer to about 1/30 of a second. There are also instruments you can buy to get more accurate readings.
    BTW, I was very happy to record a 3.9 in my 2016 refresh 90D. (PowerTools had given me 4.25)
  13. jddssc121
    jddssc121 Member
    Las Vegas, NV
    nitpick - "quick" not "fast" ;)
