How I Recovered Half of my Battery's Lost Capacity
KenC
3,496
3,179
Maine
My car shows 230 miles at 90% and around 256 at 100%. Tesla said over the app that my battery is fine and that the car is underestimating my range. If i wanted to fix it, they suggest letting battery go down to 5% and the. Charge to 100%. Then going forward, I should let battery drain to 15-20% before charging back to 90% and it will fix itself over time. I haven’t tried that and just continue to charge from around 70% back to 90% daily.
Maybe test a new charging routine. Rather than cycle between 70 and 90% SOC, try something radically different, like 50 to 70%, and then charge up higher for weekends, if you plan to go somewhere.
Gizmo35
134
145
San Diego, CA
I decided I will let it drain down to around 5% and sit for a couple hrs and recharge and let it drop to 20% a few times before recharging and see if anything changes.
scottf200
3,880
3,460
Chicagoland ModelX S603
You can automatically let it sit for X hours by just using the scheduled 'departure time'. It will calculate when to start charging based on your targeted SOC % (state of charge) and your charging speed (kW). This makes the 'sit for X hrs' automatic. And can add randomness to your array of lower SOC values if your miles uses all week and weekend changes.
Reactions: Gizmo35
dsnows
214
174
Winchester, VA
Thanks for the detailed info. I have one question. If I charge to 90% then lower the charge limit to 50%, and drive daily (even if just a few miles) until the charge level drops to 50%, but I plug in each night, will the contacts remain open, so the car can measure the OCV? The car will be plugged in but not charging because of the low charge limit setting below the current state of the battery charge level. Or, does the car have to be left unplugged to properly sleep and do what you say?
Kianaf808
22
2
Honolulu
Your logic is good and the data support it. I was thinking along similar lines and stopped charging my battery every day although I keep it plugged in. Part of the reason is I get free charging at work, so I have generally been charging from 60-90% on Fridays and Mondays. I have never run the car below 50%, so if data below that level is required by the bms, then I would have to go much lower.
Like many others, I have been concerned with loss of 100% indicated battery range on one of my Model 3s. My P3D (build date 9/13/2018, delivery date 10/8/2018) had gotten down to 270.3 miles at 100% charge on January 20, 2020, at about 30,700 miles, which is a loss of 40.8 miles since the car was new.
I posted about going to the service center to talk with them about battery degradation, which I did on March 9, 2020. It was a great service appointment and the techs at the Houston Westchase service center paid attention to my concerns and promised to follow up with a call from the lead virtual tech team technician. I detailed this service visit in the following post:
Reduced Range - Tesla Issued a Service Bulletin for possible fix
While that service visit was great, the real meat of addressing the problem came when I spoke to the virtual tech team lead. He told me some great things about the Model 3 battery and BMS. With the knowledge of what he told me, I formulated a plan to address it myself.
So here is the deal on the Model 3 battery and why many of us might be seeing this capacity degradation.
The BMS system is not only responsible for charging and monitoring of the battery, but computing the estimated range. The way it does this is to correlate the battery's terminal voltage (and the terminal voltage of each group of parallel cells) to the capacity. The BMS tries to constantly refine and calibrate that relationship between terminal voltage and capacity to display the remaining miles.
For the BMS to execute a calibration computation, it needs data. The primary data it needs to to this is what is called the Open Circuit Voltage (OCV) of the battery and each parallel group of cells. The BMS takes these OCV readings whenever it can, and when it has enough of them, it runs a calibration computation. This lets the BMS now estimate capacity vs the battery voltage. If the BMS goes for a long time without running calibration computations, then the BMS's estimate of the battery's capacity can drift away from the battery's actual capacity. The BMS is conservative in its estimates so that people will not run out of battery before the indicator reads 0 miles, so the drift is almost always in the direction of estimated capacity < actual capacity.
So, when does the BMS take OCV readings? To take a set of OCV readings, the main HV contactor must be open, and the voltages inside the pack for every group of parallel cells must stabilize. How long does that take? Well, interestingly enough, the Model 3 takes a lot longer for the voltages to stabilize than the Model S or X. The reason is because of the battery construction. All Tesla batteries have a resistor in parallel with every parallel group of cells. The purpose of these resistors is for pack balancing. When charging to 100%, these resistors allow the low cells in the parallel group to charge more than the high cells in the group, bringing all the cells closer together in terms of their state of charge. However, the drawback to these resistors is that they are the primary cause of vampire drain.
Because Tesla wanted the Model 3 battery to be the most efficient it could be, Tesla decided to decrease the vampire drain as much as possible. One step they took to accomplish this was to increase the value of all of these resistors so that the vampire drain is minimized. The resistors in the Model 3 packs are apparently around 10x the value of the ones in the Model S/X packs. So what does this do to the BMS? Well, it makes the BMS wait a lot longer to take OCV readings, because the voltages take 10x longer to stabilize. Apparently, the voltages can stabilize enough to take OCV readings in the S/X packs within 15-20 minutes, but the Model 3 can take 3+ hours.
This means that the S/X BMS can run the calibration computations a lot easier and lot more often than the Model 3. 15-20 minutes with the contactor open is enough to get a set of OCV readings. This can happen while you're out shopping or at work, allowing the BMS to get OCV readings while the battery is at various states of charge, both high and low. This is great data for the BMS, and lets it run a good calibration fairly often.
On the Model 3, this doesn't happen. With frequent small trips, no OCV readings ever get taken because the voltage doesn't stabilize before you drive the car again. Also, many of us continuously run Sentry mode whenever we're not at home, and Sentry mode keeps the contactor engaged, thus no OCV readings can be taken no matter how long you wait. For many Model 3's, the only time OCV readings get taken is at home after a battery charge is completed, as that is the only time the car gets to open the contactor and sleep. Finally, 3 hours later, OCV readings get taken.
But that means that the OCV readings are ALWAYS at your battery charge level. If you always charge to 80%, then the only data the BMS is repeatedly collecting is 80% OCV readings. This isn't enough data to make the calibration computation accurate. So even though the readings are getting taken, and the calibration computation is being periodically run, the accuracy of the BMS never improves, and the estimated capacity vs. actual capacity continues to drift apart.
So, knowing all of this, here's what I did:
1. I made it a habit to make sure that the BMS got to take OCV readings whenever possible. I turned off Sentry mode at work so that OCV readings could be taken there. I made sure that TeslaFi was set to allow the car to sleep, because if it isn't asleep, OCV readings can't get taken.
2. I quit charging every day. Round-trip to work and back for me is about 20% of the battery's capacity, and I used to normally charge to 90%. I changed my standard charge to 80%, and then I began charging the car at night only every 3 days. So day 1 gets OCV readings at 80% (after the charge is complete), day 2 at about 60% (after 1 work trip), and day 3 at about 40% (2 work trips). I arrive back home from work with about 20% charge on that last day, and if the next day isn't Saturday, then I charge. If the next day is Saturday (I normally don't go anywhere far on Saturday), then I delay the charge for a 4th day, allowing the BMS to get OCV readings at 20%. So now my BMS is getting data from various states of charge throughout the range of the battery.
3. I periodically (once a month or so) charge to 95%, then let the car sleep for 6 hours, getting OCV readings at 95%. Don't do this at 100%, as it's not good for the battery to sit with 100% charge.
4. If I'm going to take a long drive i.e. road trip, then I charge to 100% to balance the battery, then drive. I also try to time it so that I get back home with around 10% charge, and if I can do that, then I don't charge at that time. Instead, let the car sleep 6 hours so it gets OCV readings at 10%.
These steps allowed the BMS to get many OCV readings that span the entire state of charge of the battery. This gets it good data to run an accurate calibration computation.
So what's the results?
On 1/20/2020 at 30,700 miles, I was down to 270 miles full range, which is 40.8 miles lost (15.1 %). The first good, accurate recalibration occurred 4/16/2020 at 35,600 miles and brought the full range up to 286 miles. Then another one occurred on 8/23/2020 at 41,400 miles and brought the range up to 290 miles, now only a 20 mile loss (6.9 %).
Note that to get just two accurate calibration computations by the BMS took 7 months and 11,000 miles.
So, to summarize:
1. This issue is primarily an indication/estimation problem, not real battery capacity loss.
2. Constant Sentry mode use contributes to this problem, because the car never sleeps, so no OCV readings get taken.
3. Long voltage stabilization times in the Model 3 prevent OCV readings from getting taken frequently, contributing to BMS estimation drift.
4. Constantly charging every day means that those OCV readings that do get taken are always at the same charge level, which makes the BMS calibration inaccurate.
5. Multiple accurate calibration cycles may need to happen before the BMS accuracy improves.
6. It takes a long time (a lot of OCV readings) to cause the BMS to run a calibration computation, and therefore the procedure can take months.
I would love if someone else can perform this procedure and confirm that it works for you, especially if your Model 3 is one that has a lot of apparent degradation. It will take months, but I think we can prove that this procedure will work.
I just do exactly like the manual says: Charge everyday, no matter what. And going low percentage of charge and then charging does not have any effect on the battery. Simple.
house9
354
378
Ok, so I let it drain down to 8% over a course of 4 days and then recharged to 100%. Displayed is now 263 miles at 100%, Up from 256 miles last week. Will keep the updates coming.
Based on the original post, I think the key thing is did your car go into deep sleep for long durations at different states of charge?
Reactions: scottf200
mastre
73
66
Dallas
One weird limitation I found with "departure time" charging, which isn't present with "start charging @ X:XX AM" charging, is that it seems there's no way to disable cabin conditioning, something I don't use and do not want to use. Did I just miss something obvious, or is just a silly gotcha that's interconnected for no particularly good reason?
Reactions: PNWLeccy
scottf200
3,880
3,460
I didn't go out to my car but saw this on an image search. Does yours not show that check box?
Below via: [New feature] Tesla Secheduled Departure
Reactions: KenC
scottf200
3,880
3,460
It looks like they changed the interface in some OTA as I just went out to my X to see how mine was set up. 'Preconditioning' is in the 'Settings' dialog box. HTH
Lois Ida
New Member
Apr 1, 2021
Naples, Fl
So, to summarize:
Thank you but it does seem to contradict Tesla recommendation to keep the car charged. I have a Y model. Are the batteries different?
Gizmo35
134
145
San Diego, CA
Update 2. Now 241 miles at 90%. After letting it drain down to below 10% and charged back to 90. It is slowy going up. I think i have peace of mind now that the range is ok. Dont know if I will continue not charging daily since its just an inaccurate display which i prefer to have than doing what is considered not good for the battery.
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
9,425
11,326
San Diego
That's not a bad recovery; now only ~16% capacity loss instead of close to ~20%, according to the BMS estimate.
Some bouncing around of the estimate does occur (on some vehicles?). I see about 1-2% typically. I'm glad the estimate has increased by ~4% for you; it definitely seems like there was some systematic error on the estimate. It'll be interesting to see how it goes from here. Check back in from time to time!
Reactions: Gizmo35
PhysicsGuy
92
89
I've seen the service manual excerpt for the model 3 posted a few times. The BMS starts balancing at voltage above 4.0
4.0 volts (or more precisely 3.97 volts per group) corresponds to 80% in for typical Li-ion batteries. This is consistent with the idea that you do need need to go to 100% (or even 90%) for the purpose of balancing.
Reactions: KenC
PhysicsGuy
92
89
This is a key point to keep in mind. Charging to 90% or letting you car sit at 10% causes real battery capacity loss, albeit small. It is preferable, in my opinion, to stay in the 20 to 80% range when convenient, rather that to venture outside it for no real reason.
KenC
3,496
3,179
Maine
we have no evidence that you have more degradation in any significant way charging to 90% daily than to i.e. 80% daily.
Everyone's definition of "significant" is different, but it seems intuitive that charging to the more extreme range of voltages and SOC percentages is not as healthy for a battery than staying in the less extreme middle ranges. While it's unlikely to matter all that much, it does seem that many people are more sensitive to small range changes than expected; otherwise, why would there be so many comments on these threads?
When people pay for more range, and then within a couple years seem to lose that range, where now their model's range is less than that of a smaller-batteried model, it's understandable that some people get upset. Of course, if they had bought the smaller-batteried model, that would now have even less range, but appealing to logic doesn't always help.
Model 3 pricing is primarily differentiated by battery size, so people are sensitive to when their battery seems to lose range, almost instantly when they take their 3 home.
PhysicsGuy
92
89
Research by battery scientists and referenced at Battery University, for example, quantifies this and is obviously well known and acknowledged. What you say could be true, depending on how you define "significant". I am not trying to change your behavior, nor am I judging it. It is a choice. Accurate information will help new owners make their own choices.
