jelloslug
You cannot access it so it's not usable.Nothing unusable about it. Maybe not wise, but usable.
No, you're wrong because you're thinking of something else and didn't understand what @jelloslug was referring to. The question was about whether the battery going totally empty was harmful to it. Here was the question from @Pinot.Noir :Nothing unusable about it. Maybe not wise, but usable.
"Isn't it bad for the battery to run to zero?"
It means that only 95% of your usable kWh are above 0km. 5% is in the below zero zone. This comes from 178 Wh/rated km actually seen while driving divided by 188Wh/rated km shown on the graph. In my car (refreshed 60/75) 5.3% is below zero. See this post for more information.
Since you have no Service Centers within reasonable driving distance, I suggest you consider using TM-Spy to get detailed data about your pack, including voltage for each of the 84 bricks (cells). I figure you have over 16% degradation on your battery (253km rated @ 90% SoC versus about 302km when new.) That seems way out of line compared to what others report.
have proven that (in my car at least) this is not true. Zero miles on the dash is 3.8 kWh usable remaining energy according to the BMS.
You cannot see the buffer since it's not accessible.I think (almost) everyone on this thread interprets "run to zero" as "run to zero miles" (or km) on the instrument panel.
If the pack is taken to zero volts, or whatever qualifies as 0 kWh of total remaining capacity, the pack will be ruined. The car won't let you get anywhere near that point by doing the mandatory pack protection shutdown at or near the 0 kWh usable remaining energy point as calculated by the battery management system (BMS). However, the driver doesn't know what the BMS has calculated. The driver only knows 0 miles on the dashboard. I think you imply later in your post that you believe that 0 miles on the dash and BMS-calculated 0 kWh usable remaining energy are the same point (or at least very close). I have proven that (in my car at least) this is not true. Zero miles on the dash is 3.8 kWh usable remaining energy according to the BMS. And it is usable, because I used it. And took photos. And posted them.
I agree that the BMS remaining energy figure is an estimate, but, at least in mild weather with a warm pack and gentle use of the accelerator pedal, it seems to be accurate +/- 0.1 or 0.2 kWh. I highly doubt it is ever off by 2 kWh, never mind 3.8 kWh.
Maybe my car is a unicorn, but somehow I doubt it. Other models may well have different size cushions, but if anyone can show (using current firmware) a cushion less than 2.0 kWh, I'll eat my hat.
You can see the difference or buffer with TMSpy. If you have your battery % shown on the dash, and look at it with TMSpy, it's usually 3 to 5% difference depending on the pack size.You cannot see the buffer since it's not accessible.
Can't tell if you're kidding or not, but don't just buy one assuming it will work. Most generators will NOT work to charge a Tesla. The Tesla charging cord is particular about having a real ground connection, and the vast majority of generators out on the market don't have one. Search this forum or the other one at Tesla's site for information on generators and which ones may work.I think I will buy generator for insurance, I got to 10 and was scared to death.
No, that's not any problem. You can go a few weeks, and it will only lose around 1 or 2 miles a day IF (pay attention here) you don't keep checking on it. The car will go into a hibernate/sleep kind of low power mode within about the first 24 hours and I think a deeper sleep mode within 48 hours. But if you're running something like TeslaSpy or one of those other remote monitoring utilities that's always poking the car every few minutes for data, it's basically keeping the car awake and using more energy, and it can never go into those power saving modes. The same goes for not connecting to it with your phone app every day to check on it too.Mother tesla told me yesterday, never leave car in airport for more than 5 days or it will be dead meat.
Can you clarify this for me?
Okay so if we look at a 2014 s 60, the battery itself should have around 61kwh of total capacity, of which 58.5kwh is 'usable'. So are you saying when the indicator shows 0 miles remaining, there is actually around 3.8kwh of remaining USABLE battery? Meaning if I start with a 100% charge, and run down to 0% (as displayed on the dash), it mean's I've only actually used 54.7kwh (or thereabouts)?
So the 0 - 100% is more like 10-100% and the bottom 10% is just completely hidden (2.5kwh left for anti-bricking and 3.8 for buffer?)
How do I go about getting this app? I can't find it on the Google Play Store.
As I understand, the battery has 14 modules, totaling 61kwh and 58.5 usable kwh. If my 100% is around 275-280, and the rated range is 178wh/km, then it would suggest I have 49 - 50 kwh of usable capacity. A loss of 8.5kwh.
The S 60 has 14 modules? Meaning each module has about 4.35 kwh of capacity. Could it be that I've got 2 bad modules? How would the car handle a bad module?
is it bad for the battery to have a bad module or can it handle fewer modules fine? I figure one could simply replace a faulty module but then the new module will be a completely different age to the old ones.
Any suggestions for a guy with no access to a Tesla Service Centre?
I can't remember the exact number version right now, but people did track down exactly what firmware version that not just "changed", but eliminated the below 0 driving buffer. It was in the 5.x series somewhere.Also, there is reason to suspect that this usable buffer below zero km has been changed over the various firmware versions (probably more than once).
That's a pretty broad statement. The 4kWh brick buffer is there precisely to prevent this kind of damage. I'm not suggesting that going down to 0RM is completely safe, but there is no evidence I know if that indicates running this low damages the battery.Yes it is bad. You don't even want it to get down to the last few percent if you can avoid it.
You use the past tense there like it doesn't happen any more, and I don't see why. There continue to occasionally be reports here on this forum of cars shutting down with a couple of miles range still showing.There have been many firmware versions since 5.x, and therefore many opportunities for Tesla to put it back. My guess is they got tired of people having a shutdown while still showing a few miles of range remaining, and then arguing that Tesla should pay for the tow.
