Over the weekend, I had a chance to borrow and test a family member's
2022 Model Y. There are some interesting results after testing.
First the good news:
Yes, the front 2 USB-C ports are now 12V capable, at up to 3A.
Front USB-C ports:
USB-PD 3.0
5V/3A
9V/3A
12V/3A
And it's able to supply 12V/3A (36W) to a load with no issues. The voltage drop is caused by a long USB-C cable I used:
And now for the bad news:
As soon as a second USB-C load is plugged in to the second USB-C port up front, the 12V rail on each disappears:
Front USB-C ports (2 concurrent loads):
USB-PD 3.0
5V/3A
9V/3A
Looks like the front USB-PD power supply in the car is
not able to supply two loads at 12V/3A (36W) concurrently.
However, it is still able to power two devices at 9V/3A (27W) concurrently, which is identical to the rear ports power rating:
And for the final test, I tried concurrently loading one front USB-C and one rear USB-C at their maximum power rating.
The front USB-C was able to power a load at 12V/3A (36W) while the rear was able to power at 9V/3A (27W), for a total of 63W.
So looks like the front USB-C and rear USB-C ports are powered by
two independent USB-PD power supplies in the car, so they do not affect each other.
Unfortunately, I currently only have 2 USB-PD testers and USB loads. But if I had 4 of each, it would be interesting to see if the car can provide 4x (9V/3A = 27W) for a total of 108W from all 4 ports!
My conclusion from all this:
1. If you have a high power device (laptop, iPad Pro, etc) that require the 12V rail (12V/3A = 36W), plug it into one of the front USB-C ports, and keep the second front port empty.
2. If you need to power another device while the above device is charging, use the two rear USB-C ports first, which provide up to 27W (9V/3A) each.
3. If and only if you have to power a 4th device, then use the second USB-C port up front, which will cause the voltage to be limited to 9V/3A max (27W) for each front USB-C port.
If your device only charges at 5V (15W) or 9V (27W), then don't worry about any of this. Just plug it into any of the 4 USB-C ports in the car and it will charge at max speed, concurrently.
