How to measure power consumption at home?
rossini
93
45
Marin County, CA
I apologize in advance if this has been asked a million times already but I did use the search function and the results were a bit garbled. I just got an MY (first EV) and I'm wondering if there is a very simple way in which Tesla has allowed an owner to easily determine how much electricity per month was directly related to charging the car. I have it set up to only charge after midnight to take advantage of the cheapest rates but does the car or perhaps a third-party app have a way of determining how much was attributable to charging each month?
Pilot1226
355
155
There are some third party apps like Stats and TeslaFi. Some are a one time fee, some are a subscription. That will let you see “lifetime” charging after installed.
Puma2020
328
320
New Hampshire
The non electronic way, is to go out and read your meter each day, roughly at the same time each morning and/or evening.
After a few day, you'll have an fairly good idea of what you are using.
Do this on the day before plugging in your car, then on the day you plug in your car and the day after.
I recommend doing it each month or season. Very interesting to track what you house is pulling from the grid.
It is also useful to figure out what size you need if you ever do solar panels.
PM me if you want more solar panel info. I do not own, operate or am affiliated with any solar company.
I have had solar panels for a few years now and am willing to provide whatever little guidance I can.
user212_nr
1,407
732
US
There are some thirds party apps, but they require a monthly fee and giving them your Tesla credentials. ex. Teslafi
One "easy way" is to set a trip counter on the car. That will give you the number of kWh used excluding the time that you spend in the car not driving, and any "overhead" while charging.
Klau2
398
228
Boyds, MD
I use Chargepoint HomeFlex as my charger at home. It cost me almost nothing for the unit after state and local utility rebate. The Chargepoint app does tell me how much electricity it used per session and by month. It also estimate how much that cost me based on the local utility rate.
Reactions: Johnny Vector
jonboyTMY
57
34
Randolph, NJ
Shouldn’t the Gen 3 WC have this same functionality?
wycolo
3,068
422
WA & WY
If you just use the wimpy charge cable you can buy a relatively cheap digital watt-hour meter for just that purpose. The 240v units are designed to mount on din rails so should be put in a small metal box.
Johnny Vector
75
111
Maryland
Unless your home heating is provided by electricity, and you're in heating season. Then the electrical use per day is dominated by that, so it's hard to get a baseline.
If you live in an area where the electric utility has smart meters, they probably have a way for you to see your usage broken down hourly. I can clearly see when my car is charging on the hourly graph.
K2500Z71
183
121
Upstate NY
You could just do the math too. Your car displays the amps and volts it’s drawing while charging. Watts=volts x amps
For example if you’re charging at 48 amps on a 240 circuit:
240v x 48a = 11,520W (or 1.15kW)
If you charged for an hour, you consumed 1.15 kilowatt-hour (the billing unit that your electric utility uses).
TMThree
1,116
1,602
Or just install your own monitoring system, like adriankumpf/teslamate
I have mine running on AWS Lightsail - $3.50/mo. You can also host for free on google cloud, or at home on a raspberry pi.
Works better than Teslafi, with a much nicer UI too. And credentials don't go to a 3rd party.
pics: Screenshots | TeslaMate
JimBob 909
Little Red Raven
Sep 16, 2019
62
37
Southern California
I go to my So Cal Edison site and it shows me daily usage. I get a huge spike on days I charge. I can deduct "daily use" and get a close amount of electric used for charging. Doesn't cost me to use the Edison site. Since it shows my tier rate, I can figure what it cost to charge.
Johnny Vector
75
111
Maryland
Hmmm. "it reads the current one million times each second". That's either wrong or stupid. There's nothing useful to be learned by sampling faster than 240 Hz. I guarantee they didn't put in a 1 MSPS A/D just for fun. Just like I'm not interested in a solar power company whose marketing doesn't know the difference between kW and kWh, I'm not interested in a power monitoring company whose marketing doesn't understand their actual hardware.
Mo del Y
New Member
Jul 5, 2020
4
4
94086
Correct me if I’m wrong, but wouldn’t that be 11.5 kW ?
Reactions: Rocky_H and kayak1
cwerdna
3,348
2,195
SF Bay Area, CA
Yep. I was going to mention that or JuiceBox.
OP might still have delivery and bills from PG&E. if so, one can monitor whole house electricity usage via devices like at PG&E Stream My Data (e.g. Rainforest EAGLE gateway).
gfunkdave
120
164
Portland, ME
Well, if you read the website more thoroughly you'd see in the specs the following:
Signal Processing
1MHz Sampling Rate (4M data points per second) 1GHz ARM Processor
There may or may not be a point to it as far as you know, but they implemented it. I suspect it's a byproduct of the architecture they chose and Marketing decided to trumpet it as a selling point.
