I am no longer able to access the gateway through my IP address. I get the message to download the pros app. I downloaded the app. How do we use it as a homeowner similarly to how we logged into the gateway through the IP?
That was not an option. But, even if I am able to access, eventually it would no longer be an option. So how do we use the app as an alternative?Continue
Upgrade Later
No need for pro app.
You can log in to Tesla One as an External Partner using your Tesla credentials. Then navigate to More / Tesla Device Setup / Scan QR Code and scan the QR code behind your gateway door. You'll need to be nearby and connect to the gateway wifi each time you want to use the app.That was not an option. But, even if I am able to access, eventually it would no longer be an option. So how do we use the app as an alternative?
THANK YOU @offandonagain - this right here is what I've been searching for and was unable to find until now. Using this very simple procedure, I'm now able to log into my gateways with the Tesla One app and see stats, change settings, etc.You can log in to Tesla One as an External Partner using your Tesla credentials. Then navigate to More / Tesla Device Setup / Scan QR Code and scan the QR code behind your gateway door. You'll need to be nearby and connect to the gateway wifi each time you want to use the app.
I need to try this with my Powerwall 3...THANK YOU @offandonagain - this right here is what I've been searching for and was unable to find until now. Using this very simple procedure, I'm now able to log into my gateways with the Tesla One app and see stats, change settings, etc.
I want to try with my Powerwall 3s. I did not see a "More" option. Is these where you start in the app?THANK YOU @offandonagain - this right here is what I've been searching for and was unable to find until now. Using this very simple procedure, I'm now able to log into my gateways with the Tesla One app and see stats, change settings, etc.
Also the screws that hold the cover on are one-use screws with a compressable gasket that needs replacement to maintain waterproof integrity.Bottom right of your screenshot.
For PW3 it's not straightforward unfortunately: the QR code to connect to its wifi is behind the glass cover. So you'd have to take a picture of the QR code while it was being installed or serviced.
Ahh, too late for me then. I wish I had done it while they were installing.Bottom right of your screenshot.
FWIW, my install team told me only the top two screws are the one-time use screws.Also the screws that hold the cover on are one-use screws with a compressable gasket that needs replacement to maintain waterproof integrity.
