I suppose from the NEC point of view (that focuses more on new design), this is correct -- a "standard" branch circuit needs to be "upgraded" for continuous load, but then it really just becomes a larger "standard" circuit capable of supplying a lower continuous load. On the other hand, if you have an existing circuit to which you want to attach a continuous load, then the reverse operation needs some sort of name. I suppose you could use the terms "reduced" or "downgraded", but the NEC seems to use terms like "derate factor" etc.The DIP switches set your branch circuit rating, which is 125% of the current drawn by the car; or, the car knows to draw 80% of what the DIP switches are set to.
I don't use "derated output", that term is incorrect in the context of the NEC here.
